LED conversion
Old Nov 2, 2011 | 10:21 PM
peshewa's Avatar
peshewa
Default LED conversion
Okay folks, I have a notion to use as many LED bulbs as possible in my Ram. I have tried using LED bulbs for signal and tail lights in a Bonneville I used to own, but the PCM does not recognize the low voltage draw of the LED's, you have to use aluminum sheathed resistors & a special blinker module to make them work, and not that greatly I might add. I went back to incandesants in that car then I got rid of it. I am curious if any of you have done the LED signal & tail lights in LED and I want to know if any of you encountered a need for special extras like the resistors and special blinker etc that I did with my Bonneville. I am wanting to upgrade to LED tail assemblies but I really want to know how much of a pain it will be up front. Your thoughts folks?
Old Nov 2, 2011 | 10:25 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Not anything that I know of.
No "Lamp Out" crap to deal with like on the 3rd gens.
You should be good.
Old Nov 2, 2011 | 10:36 PM
Dycrow27's Avatar
Dycrow27
I bought LED tail light bulbs for my euro taillights and what happened was my turn signal was extremely fast because of the low voltage LED's. I just bought a LED friendly Relay for like 12 dollars at advanced auto parts.
Old Nov 2, 2011 | 10:40 PM
EndIsNear's Avatar
EndIsNear
If you do the rear lights and the front signals you will have problems. Your blinkers wont function at all. I had to put resistors on the front and back lights to run all LEDs. Only drawback is they blink fast, like your normal signals would blink when you had a bulb out, but everything blinking correctly. I just haven't researched enough to install a blinker "fix"
Old Nov 3, 2011 | 03:07 AM
biggreen2500's Avatar
biggreen2500
i bought led lights on ebay for 119.00 dollars.
they have releys built in place i know this ain't what your looking for but its a cool easy and a somewhat cheap upgrade you can do that adds style and a safety factor to the rear of your ram
http://www.ebay.com/itm/94-95-96-97-...item43aaa4f8f4
Old Nov 3, 2011 | 03:08 AM
biggreen2500
also for the blinker fix i use these people as they are local they have a shop in my town...
i runt here hid kits and i have all the led lights in my dome lights and etc.
heres the blinker fix
http://www.v-leds.com/BlinkerWarning...orLanding/true
Old Nov 4, 2011 | 09:40 PM
Terribly's Avatar
Terribly
Is the LED friendly relay just one that you put in place of the original turn signal relay in the engine bay?
Old Nov 4, 2011 | 10:11 PM
J415's Avatar
J415
Just curious, but are those lights DOT approved? If not, you just might get pinched.
Old Nov 5, 2011 | 12:55 AM
peshewa's Avatar
peshewa
In my area, I have never been busted for running LED signals or brake lights, cops here only care that they work correctly. I will eventually to the ready made LED rear fixtures from ebay as mentioned above. I want the from signals to be LED, but I guess I will have to use the resistors. I have some still new in the bag I got on ebay last year for my old car. I know the lights in my old bonneville are sort of connected to the computer, so even with resisters & the special blinker unit they just did not work, but the interior lights were great. Thanks for all the input guys! Now I have some plans on exactly what to do.
Old Nov 5, 2011 | 03:28 AM
biggreen2500
yes they are DOT legal mine have a DOT number on the bottom of the lense its super small.. and it also says they are DOT legal on that ebay website...
when i was in search and rescue with my local sheriff department. i did bring up that question to a traffic deputy. cause there are some lights that don't have a dot number. but as long as you have a red reflector and there not blacked out you won't have any problems. but on some of them that are all clear and you need a red light bulb those of ones that you can get fined for
but that here in my area of washington so i'm it may be different with you aera
also V-leds.com is a good place to check out for led light bulbs there super bright i have a set in my front blinkers they blink amber and white and i have them in my dome lights there they brightest leds i've ever had or seen
