Using coil spacers bad?
Old Nov 5, 2011 | 01:30 AM
Ramcountryboy's Avatar
Ramcountryboy
Oh sorry, i missed the 2wd thing, on 4x4 its a little different, and i guess ill clarify "a buncha stuff" as shock tower, sway bar, and track bar, at least thats what worked for me
Old Nov 5, 2011 | 03:14 AM
biggreen2500's Avatar
biggreen2500
my 2001 dodge ram 2500 2in level kit is on the top of the spring between the spring and shock tower. and i'm running stock length shocks
Old Nov 5, 2011 | 01:43 PM
grox's Avatar
grox
I would (and have) just remove the sway bar for good. It noticeably improved ride and doesn't make any noticeable difference in body roll or brake dive.
You don't need to remove the shock, just take the nut off the top.
Old Nov 5, 2011 | 04:44 PM
Ugly1's Avatar
Ugly1
If you use your truck for hauling heavy stuff you might want to shelf that sway bar just in case. Big loads with no sway bar at highway speeds can be a real white knuckler, especially in the corners.
Old Nov 5, 2011 | 05:48 PM
Silver_Dodge's Avatar
Silver_Dodge
Just to clarify - on 4x4's removing the front coil spring is relatively easy, and does not require a compressor at all. I replaced my stock coil spring with a 2" lifted spring, then again later with a 3" spring. the only thing I disconnected was the shock tower and the sway bar links. That's it. It is very safe - i'd say safer then using a spring compressor which in my opinion are not safe.
