Bearing in Power steering is toast (I think)
Old Nov 5, 2011 | 11:41 AM
RageGuy's Avatar
RageGuy
Default Bearing in Power steering is toast (I think)
Recently noticing this ticking sound coming from the Power steering pump pulley. It actually sounds alot like engine tick, but im 100% sure its the pulley. if I hit it with a little WD-40 it gets noticeably quieter for a while, but always comes back.
Question is, would changing the pulley itself remedy this? or is the bearing inside the pump assembly? Meaning id need a whole new assembly?
Thanks.
EDIT: Wow, sorry for the horrible spelling in the title, stupid phone auto correct.
Old Nov 5, 2011 | 12:05 PM
Check and see if there isn't just some dirt in the pulleys grooves first.
Old Nov 5, 2011 | 12:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Damn, LOL. PITA phones. I wonder if you can edit it too? I don't know, I never tried.
Old Nov 5, 2011 | 12:27 PM
RageGuy's Avatar
RageGuy
Cant edit the title =/ just the post.
RageGuy's Avatar
RageGuy
Nope..shes clean.
Old Nov 5, 2011 | 12:47 PM
zman17's Avatar
zman17
I'd say replace the pump. Just replacing the pulley won't help. The bearing is still in the pump.
Hmm, I wonder why you can't change the thread title. Maybe HeyYou can? I don't know.
Old Nov 5, 2011 | 03:04 PM
RageGuy's Avatar
RageGuy
That's what I figured... =/
Thanks for the info.
Old Nov 5, 2011 | 03:11 PM
gdstock's Avatar
gdstock
Power steering pump is not expensive. Just be careful pullling pulley off and don't beat it onto the new pump. Most auto supply stores like AZ and Orelieys have a puller in their loaner tool program. If not, use a bolt to thread into pump shaft with a couple of washers and a nut. Use the nut to set the pulley on the shaft. The pump won't take much abuse.
Old Nov 5, 2011 | 03:43 PM
zman17's Avatar
zman17
Most pumps come with a bolt and nut of some sort to get the old pulley off. However, I have the tools, but in your case, I wouldn't leave the parts store without the pulley being swapped.
Old Nov 5, 2011 | 05:50 PM
gdstock's Avatar
gdstock
Mine did not have a nut. Press fit only. May be a difference in year models though.
