fuel injection to carberated.
Old Nov 5, 2011 | 03:41 PM
Hahns5.2's Avatar
Hahns5.2
Way too much work for no benefit. Megasquirt 2 would end up being cheaper and is infinitely tunable.
Old Nov 5, 2011 | 03:43 PM
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by zman17
It would be cheaper to get a 72 power wagon. lol Not to mention, it is completely illegal. Fed not local..
What's wrong with having a '72 Power Wagon? If you are making fun of me i completely missed it haha
Old Nov 5, 2011 | 03:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
LOL, no, not making fun. I just worded that post wrong as far as you go.
Old Nov 5, 2011 | 04:09 PM
Wombat Ranger
Honestly I get almost as good mileage with my '72, non overdrive, with 39's as i do with my efi overdriven '95 haha. But my 318 runs like a top, and my 360 needs a bit more work and tuning.
Old Nov 5, 2011 | 05:50 PM
crazzywolfie's Avatar
crazzywolfie
why do people always bring up gauges when someone talks about swapping to carb? i bet most of the gauges are hooked up separate from the computer anyway. i think the only one that may be tricky is the speedo. hooking up an old style voltage regulator is simple. i think it would probably cost you at least $1000 to convert to carb. the intake that you would need would probably cost you at least $300 plus the carb itself $300 and depending on what type of ignition system you go with it could cost $100-200, charging system would cost you about $50 plus whatever a fuel regulator goes for. there may be outher parts i am missing but i can not think of them right now. aren't the transmissions electrically controlled from about 96 and on?
Old Nov 5, 2011 | 05:53 PM
gdstock's Avatar
gdstock
As I can read gauges with MTG 2500 connected to OBD port, I am thinking most of them do go through PCM. Not sure, but i can read fuel level, engine and tranny temp, intake air, etc......
Old Nov 5, 2011 | 06:13 PM
crazzywolfie
i am also betting your truck has 2 of most of the sending unit. need be you leave the computer there and add the stuff you need to run the carb. for a whole week i ran a electric speedo in my 81. it was super simple to hook up and for the longest time i thought i need the computer to have a electric speedo.
Old Nov 5, 2011 | 06:39 PM
Looking at the schematics... it appears on the 96-97 trucks, only the tach is driven by the PCM. interesting.
Old Nov 5, 2011 | 07:25 PM
rumble_truck's Avatar
rumble_truck
Say goodbye to a passing score on your emissions test.
Thank god there's no emissions in FL
