A little help please
Old Nov 5, 2011 | 09:36 AM
What all have you done to the truck engine-wise? Might be time for better tunes.
zman17's Avatar
zman17
Retired Moderator - RIP
You should consider buying an SCT tuner or SuperChips.
LOL at HeyYou,
Old Nov 5, 2011 | 09:50 AM
S S0DEN's Avatar
S S0DEN
The truck has been rebuilt with using:
Eagle rotating Assy for the Magnum - 4340 forged steel crankshaft (competition kits), I beam or ESP 4340 H beam connecting rods, forged pistons with valve reliefs, moly file fit piston rings, main and rod bearings.
I found both heads were cracked between the intake and exhaust ports, so we went with Summits Mopar Indy Race Heads: http://www.summitracing.com/parts/RHS-20300/
Had to do a lot of machine work to those heads to make them work I guess. But the price was good for the heads.
Machined the intake and throttle body for more flow, matched the SLP Headers with the exhaust ports, high flow Y pipe, pass through cat (gutted with pass through pipe welded in) and Flowmaster cat back 3 7/8" to Flowmaster duel outlet muffler, split duels out the rear.
The exhaust was already in place prior, no check engine light...
Old Nov 5, 2011 | 09:51 AM
S S0DEN's Avatar
S S0DEN
Tuner or a good reprogram is in my plans as we are using more air, the ECM will try to adjust the fuel mixture.
Old Nov 5, 2011 | 09:53 AM
Even the canned tunes would find you some more power. Have a chat with Hemifever, and see if he thinks custom tunes are in order. (I don't think so, but, hey, better to ask the expert. )
Old Nov 5, 2011 | 11:17 AM
S S0DEN's Avatar
S S0DEN
Thank you for the information, will do.
Old Nov 6, 2011 | 10:24 PM
S S0DEN's Avatar
S S0DEN
Update: I have to replace a couple things before I can start it, should be a week... LOL
Old Nov 24, 2011 | 10:25 PM
S S0DEN's Avatar
S S0DEN
Double post...
Old Nov 24, 2011 | 10:26 PM
S S0DEN's Avatar
S S0DEN
Completed minus the fuel sync, I am looking to get the actual scanner to set the sync myself.
Runs great, a little rich right now, but better rich then lean for the break in period.
Only issue I had was the Indy Racing heads had a casting block that rubbed with the headers as they expanded to form the collectors. Had to grind that casting a little to ensure their was no rubbing under driving conditions.
Also had to replace the radiator because I bumped mine when I pulled the engine and nicked a passage causing it to leak.
Engine on stand
