Transmission wont shift from 1st to 2nd
Old Nov 5, 2011 | 12:31 PM
Dycrow27's Avatar
Dycrow27
Default Transmission wont shift from 1st to 2nd
My transmission will shift perfectly fine when driving when in drive but it does nothing when i use the gear shifter to go from 1st to 2nd it just stays in first. Its not a big deal but i would like to know what the problem could be.
Old Nov 5, 2011 | 12:37 PM
It should shift eventually...... how high do the RPM's get?
Old Nov 5, 2011 | 12:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe the linkage is not adjusted correctly. What happens when you start off in 1st and move the shifter to D ?
Old Nov 5, 2011 | 01:04 PM
gdstock's Avatar
gdstock
I'm thinking adjustment as well. Especially if it functions normally otherwise. Check as zman suggested and see what happens. If that works, adjust shifter linkage underneath.
Old Nov 5, 2011 | 09:13 PM
Dycrow27's Avatar
Dycrow27
It probably is just the linkage. would a lift kit affect this? I will check more tomorrow if im in second and i drop it into first if the rpms change.
Old Nov 5, 2011 | 09:50 PM
gdstock's Avatar
gdstock
Lift kit could possibly alter this. Body lift?
Old Nov 5, 2011 | 10:08 PM
Dycrow27's Avatar
Dycrow27
yes 3'' body and 3'' suspension
