Oil Change Tip
Old Nov 5, 2011 | 05:50 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by aim4squirrels
I just park facing downhill in the driveway.
That's how I do it -- I keep all four on the ground unless I absolutely must lift it, and then I prefer stout ramps to jack stands.
I learned well from my father... the day the rear of the family's '64 Impala coupe pinned him to the driveway with the jack stands dutifully holding up the sky from their place about two feet outboard of the rear tire. After I retrieved the jack from underneath and got the car lifted off of him it turned out that he was bruised a bit but not seriously hurt, but right up until I got him loose I figured surely he must have been dying under there... what with all of his screaming like a little girl and all.
Old Nov 5, 2011 | 06:38 PM
Ecoastmotion's Avatar
Ecoastmotion
+1 to the sloping driveway technique, i never put a lot of thought into it until one day i realized that only 3.5-4 quarts were coming out of the pan even though i just checked the oil levels and it said it was full.
Also, I have seen Jack stands fail and it was not pretty. Luckily there was no one underneath the car when it happened! Ramps all the way.
Old Nov 5, 2011 | 06:41 PM
Originally Posted by Jimythefan
Great advice.
I usually fill the filter 1/2 to 3/4 with oil so the pump gets oil right away rather than pulling oil into the filter first then sending to the bearings.
Filter is after the pump. Filling the filter partially IS a good idea though, as there is less "dry time" on first startup after changing it.
Old Nov 5, 2011 | 06:45 PM
aim4squirrels's Avatar
aim4squirrels
Maybe this thread could be retitled, "The be-all, end-all oil change thread," then sticky it.
And then lock it down before everybody starts bickering about the best brand of motor oil, oil filter, and sex lube to use.
Old Nov 5, 2011 | 08:29 PM
UnregisteredUser
I've seen cheesy chineezy ramps fail, too -- that's not xenophobia, just recognition that the folks in China deliver the product as specified by the contracts awarded by their North American distributors.
I swear if I ever get rich my garage is going to have both a lube pit and a stout SOB of a hydraulic lift with the meatiest lock pins you ever saw... and try to avoid this kind of thing...
http://www.youtube.com/watch?v=pjw2gQEBSc0
http://www.youtube.com/watch?v=rIEHbD2mWIA
Old Nov 5, 2011 | 11:29 PM
Silver_Dodge's Avatar
Silver_Dodge
That is crazy.
Old Nov 5, 2011 | 11:57 PM
J415's Avatar
J415
Definitely agree with you about the lack of quality regarding china products.
The first video, the tech didn't set the lift properly. I watched a tv program where they explained what happened.
Old Nov 6, 2011 | 12:20 AM
JSTMoto's Avatar
JSTMoto
I too pre-fill the oil filter maybe 3/4 of the way before installing it. Results in a noticeable decrease of "dry start-up chatter" after the change.
Does it really make a difference? Probably not, but I've already got the opened bottle of oil under there with me to get clean oil for the filter gasket, so I might as well pour some into the filter.
Old Nov 6, 2011 | 07:20 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... That's why I didn't mention what brands I use.
Old Nov 6, 2011 | 09:14 AM
Actually, yes, it does indeed make a difference. 80+ % of engine wear occurs at startup, when there is no oil pressure. Starting with an empty filter prolongs that time. Anything you can do to make it shorter should be considered a Good Thing™.
