A/C only works at idle
Heya;
Wife just reported this, so just starting to dive into it. Driving the truck, when there is any load on the engine, the AC will not work, however when in idle it will work fine. Immediately think of either low freon or faulty condenser core, what do you guys think?
Trending Topics
I had already bought the new cap / rotor, plugs and wires (I like to change these everytime I get a vehicle). Just haven't put them in. Also looks like its leaking in the differential from the plug, so I'll probably change the fluid in that as well and clean out the vent. I wouldn't be shocked if this truck served as a tow vehicle in a past life. Drives great though right now.
Follow up to this thread as well.
Fixed this problem, it was the Check Valve, not the one at the manifold, but instead the one at the T section. Replaced the old film can with a new nickel sized one, and also had to cut off an inch of vacuum line because it was brittle and broken. But all is well as far as that goes. Again the Part # for the Check Valve is 4549209, and got it at a dealer for $4.60.
