4wd actuator vacuum lines
Old Oct 6, 2016 | 01:04 PM
dbbd1's Avatar
dbbd1
Yes, it is always good to get some closure and/or solution on threads.
Old Oct 15, 2024 | 02:04 PM
98dodgeramjames's Avatar
98dodgeramjames
Originally Posted by dodgeFF91
aight cool thanks guys! still cant figure out why it wont engage but all lines are where they should be so guna follow the "Diagnosing 4wd engagement" post I appreciate it
I can't find either one where the vent line goes into where is it on the back of the motor and the intake one somebody can describe it to help me find it
Old Oct 15, 2024 | 04:55 PM
Vent line just doesn't matter, so long as it isn't clogged.... It's the green line, should be able to see it from underneath. (though, given its age, may not be green any more.... )
Supply line will come from the bag o' snakes of vacuum lines on the passenger side of the intake. It will run down behind the engine.
An easy test for vacuum is to simply start the motor, let it idle, pull the vacuum connector off down at the cad on the axle, see if you have vacuum to either port. Keep in mind, the metal lines that run along the frame like to rust, and leak.....
Old Oct 16, 2024 | 08:38 AM
98dodgeramjames
Only two vacuum line to the CAD unit. The large hose just goes up to the frame, it's a vent tube. Vacuum lines hit hard lines at the frame. (both go to the actuator) Hard lines follow the frame back to a crossmember, follow the crossmember and go back to soft lines, that go to the switch on the t-case. Two lines go from the switch, up to the passenger side rear of the engine, one is a vent line, (I think its green) the other is vacuum source. Goes to the bag o snakes by the intake.
All right I found the green and white wire that's coming off the motor block it was above the transmission I put my hand up there and I found a loose wire now I don't know where I got I got three black lines and I don't know which one they go and somebody help me out with a diagram of where they go remember my wires are all black
