4wd actuator vacuum lines
Old Nov 8, 2011 | 10:38 PM
dodgeFF91's Avatar
dodgeFF91
Default 4wd actuator vacuum lines
hey i'm new on here but i need some help tracing my vacuum lines off 4wd actuator on 2001 ram 1500 4x4 with 5.9 360 anybody know where i could get a diagram or where they go? 4wd quit working few months ago thought it was actuator itself then found a main vacuum line was hanging no idea where it goes
Old Nov 8, 2011 | 11:25 PM
Only two vacuum line to the CAD unit. The large hose just goes up to the frame, it's a vent tube. Vacuum lines hit hard lines at the frame. (both go to the actuator) Hard lines follow the frame back to a crossmember, follow the crossmember and go back to soft lines, that go to the switch on the t-case. Two lines go from the switch, up to the passenger side rear of the engine, one is a vent line, (I think its green) the other is vacuum source. Goes to the bag o snakes by the intake.
Old Nov 9, 2011 | 04:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Nov 9, 2011 | 06:52 PM
Terribly's Avatar
Terribly
If it is in fact a vacuum line line and not the vent, and you use 4WD somewhat regularly and need it to be reliable, I would recommend the 4X4 Posi Loc. It's cable operated instead of vacuum and replaces the actuator and lines. Definitely my next upgrade (after I fix my AC and rear brakes)
Old Nov 10, 2011 | 01:06 PM
dodgeFF91's Avatar
dodgeFF91
aight cool thanks guys! still cant figure out why it wont engage but all lines are where they should be so guna follow the "Diagnosing 4wd engagement" post I appreciate it
Old Jan 7, 2013 | 08:00 PM
dodgeman.2006's Avatar
dodgeman.2006
on the green vent line there is a little plastic thing on the end up by the back of the engine do i need that for my 4x4 to work
Old Jan 9, 2013 | 02:35 PM
byronpen's Avatar
byronpen
just get yourself a posi-lock kit for your 4wd. The best money Ive ever spend, and well worth money. No more 4wd problems
Old Oct 6, 2016 | 12:01 PM
Royals2015's Avatar
Royals2015
Default Vaccum harness
Look at the harness that runs from top passenger side of engine (1 L shaped tube), down behind engine towards front drivers side and back to transfer case. Mine was melted. It's 18.50 at the dealer. Has the 4 plug setup attached that plugs into transfer case switch. Simple fix
Old Oct 6, 2016 | 12:23 PM
dbbd1's Avatar
dbbd1
^ Um, this thread is 3years old.
Old Oct 6, 2016 | 01:02 PM
Royals2015's Avatar
Royals2015
My internet was down.
Somebody else may stumble on here at some point and maybe missed that possibility
