ABS and Brake light come on
Old Nov 10, 2011 | 08:50 AM
ktdodge's Avatar
ktdodge
Default ABS and Brake light come on
I have a 99 Diesel 2500. The ABS light and Brake light come on occasionally, they always come on together, and not necessarily when braking. I stopped at a local tire shop to have the brakes checked and they said the brakes were good. Has anyone experienced a similar thing?
Old Nov 10, 2011 | 09:12 AM
If you only have RWAL, probably the speed sensor in the rear diff. Check the connections first, if that all looks good, replace the sensor.
Is your speedometer doing anything odd?
Old Nov 10, 2011 | 09:19 AM
8uzzsaw's Avatar
8uzzsaw
Make sure you check all the wiring for the sensors too. All the way to the front.
Old Nov 10, 2011 | 09:35 AM
ktdodge's Avatar
ktdodge
No, the speedometer seems ok....I'm not sure what RWAL stands for.
Old Nov 10, 2011 | 10:05 AM
8uzzsaw's Avatar
8uzzsaw
Rear Wheel Anti-lock brakes. Some models came with 4 Wheel anti-lock and some with rear wheel.
Old Nov 10, 2011 | 12:22 PM
J415's Avatar
J415
My ABS & brake lights come on when I'm in stop and go traffic. I've switched out the speed sensor with no results. Eventually, I just learned to live with it.
On a side note, ALL rams came with RWAL brakes and SOME with front wheel ABS.
Old Nov 10, 2011 | 12:30 PM
8uzzsaw's Avatar
8uzzsaw
Yeah, what he ^ said!
Old Nov 10, 2011 | 10:54 PM
95 Ram 2500's Avatar
95 Ram 2500
ok im new at this and dont know how to post anything so im posting on this one sorry but i have a 95 ram 2500 diesel and the abs and brake lights on on wont go off ive changed out the rear speed sensor and the rwal valve and bleed the whole system and the lights are still on any ideas i was thinkin it was the brake switch by the brake pedal but i dont know how to diagnos that if anybody knows anything please let me know thanks
Old Nov 10, 2011 | 10:56 PM
gdstock's Avatar
gdstock
After you did the replacing and bleeding, did you reset PCM?
Old Nov 10, 2011 | 11:01 PM
I don't think resetting the PCM will clear ABS codes. (at least, it wouldn't on a gm vehicle....)
Do you have four wheel anti-lock by any chance?
