A/C install on non A/C truck
Old Nov 11, 2011 | 09:52 AM
Dodge did indeed use the same harnesses on most trucks, with some minor differences. According to the 01 manual though, the a/c connector is black.... two wire, dark blue with black trace, and black with white trace. If you follow the wires back, should be two more connectors on it for the hi and lo pressure switches as well.
Old Nov 11, 2011 | 08:22 PM
mrbubblemaker's Avatar
mrbubblemaker
I added ac to my 95 3500. It was very easy the only thing I had to change was the selector assy. The rest was simple add on
Old Nov 11, 2011 | 11:52 PM
biggreen2500's Avatar
biggreen2500
Originally Posted by joekool4
that only works when outside temp is less than 95degrees and youre going faster than 60mph... florida gets hot, no matter what! My ranger in PA doesnt have a/c tho, dont need it up there.
i live in washington state so in the summer it works good here cause its maybe like 89 tops during the summer lol
Old Nov 12, 2011 | 12:00 AM
Bens5.9l4x4's Avatar
Bens5.9l4x4
But he's got a 2000 not an 01
Old Nov 12, 2011 | 06:50 AM
Loeborg's Avatar
Loeborg
Been doing some more research and in fact almost everything is the same under the dash. The only thing I need to modify in there is a recirc door and pop in an evaporator. Might even leave the recirc door alone, need to see what that involves. It looks like Dodge just used the same parts for all trucks since only a small # of trucks were optioned without A/C here in the states and it was easier just to put in what they had. I'm going to start piecing together parts and go for it. So if anyone has any parts, let me know what you got and how much shipped to 06831. Most expensive thing is going to be the compressor and that should be 50-75 used, max. Going to document the process and to a DIY writeup..
