Factory LSD
Old Nov 13, 2011 | 02:26 AM
biggreen2500's Avatar
biggreen2500
you gonna be better off with hvaeing a open diff my factory lsd front and rear suck there aren't much better than your open differnt in my opinion
Old Nov 13, 2011 | 04:10 AM
97tn4x4's Avatar
97tn4x4
These trucks dont have factory front lsd's. I had mine rebuilt when the gears were installed and it acts great. Sometimes it seems like a locker cause ive been flexed out on a drop off with one tire off the ground spinning and the other still pulling too. I think its just hit and miss with your luck with them.
Old Nov 13, 2011 | 04:33 AM
biggreen2500
in my glove box its saids rear axle dana 60 4.10 ratio limited slip front axle dana 60 4.10ratio limited slip..
i'll take a photo off it in the morning and post it on here tomorrow
Old Nov 13, 2011 | 09:18 AM
I would be real interested to see that. To my knowledge, dodge never offered an LSD on the front axle in the second gens.
Old Nov 13, 2011 | 12:42 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by DodgeTheDadRamTheDaughter
The trucks came with open differentials or Limited Slip. I have an open differential, i was inquiring about putting in a limited slip diff factory unit, out of truck that came from the factory with the LSD. This is my daily driver/pavement pounder/tow vehicle. With snowy and ice conditions in michigan i'm thinking a lunch box or true locker would not be the best choice. I was just wondering if a limited slip unit factory model would be worth while for $286 new or if i could find a cheap used one. I can see where the gear unit limited slips like the Auburn or Detroit would be solid units, but they are double the price. So the factory units with the clutch packs wear out that quickly, that i should just look past them?
Ok, then I understood you as intended. Indeed the cost of the better LSDs is a factor. I figured you were going for an upgrade nonetheless, but if the budget is tight then I'd recommend a NEW factory LSD installed with warranty (at best).
I want to clarify that even though the LSDs in these go out relatively easy, they are still pretty good given your driving methods. From what I gather, and my own experience, doing donuts is just not a great thing for those clips.
To give you an idea, my original lasted up until 2008. Replaced it in kind at the time...and still just fine. Mostly pavement DD, winter snow in the Tahoe area, and now some offroad trails (but really darn slow and careful).
I'm not of the camp that the factory LSDs are pure crap. They were as intended and keeping driving techniques in mind.
yeah...I get on this son!!
Old Nov 13, 2011 | 01:20 PM
Augiedoggy's Avatar
Augiedoggy
The issue is the clutch packs burn up fast.... I had mine rebuilt last year and it works great too....
keep in mind there was two different styles made in the 90's...one is supposed to hold up better than the other but I dont know which is which.
Old Nov 13, 2011 | 04:18 PM
DodgeTheDadRamTheDaughter's Avatar
thanks for the input ill check out some aftermarkets lsd's and see how much of a price difference and decide based on that
Old Nov 13, 2011 | 07:25 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Geez that username.... I mean
Old Nov 13, 2011 | 07:29 PM
Wombat Ranger's Avatar
Wombat Ranger
Has anyone tried an eaton truetrac? I like that they dont use clutches, its a helical gear setup. Thoughts?
Old Nov 13, 2011 | 08:29 PM
chadhager03's Avatar
chadhager03
Isn't dodge the father ram the daughter????? Lol
