2000 RAM 1500 5.9L 4x4 not starting issue
Old Nov 13, 2011 | 09:20 AM
zcrashz's Avatar
zcrashz
Default 2000 RAM 1500 5.9L 4x4 not starting issue
I have had this truck for about 9 months, I love it... but the other night I was driving home, and it backfired, sputtered and stalled, and now it wont start for 2 days before this happened it had backfired a time or two throughout the day, I just thought I had gotten some bad gas in there... I had a guy hook his tester to it and he says the "main brain" is bad... does this sound right? it cranks but wont start, the coil tower to the distributor is getting spark from distributor to plugs no spark, I'd really hate to spend the money on a computer that i dont need... I also used to get a #2 cyl. misfire code when i first got the truck and the engine light was on, after I got an o2 sensor code and replaced the sensor the eng. light went away and has not come back... it has always sputtered when i really get on it (passing and what not) I just always assumed it was the misfire...
Old Nov 13, 2011 | 09:22 AM
zman17's Avatar
zman17
Retired Moderator - RIP
How old is the cap and rotor?
Old Nov 13, 2011 | 03:58 PM
zcrashz's Avatar
zcrashz
not sure... the guy i bought the truck from said he just replaced all that stuff so i'd say less than a year
Old Nov 13, 2011 | 04:36 PM
zman17's Avatar
zman17
I'd start by checking the cap and rotor and the condition of the plugs.
Old Nov 13, 2011 | 05:04 PM
minitrucker's Avatar
minitrucker
mine just quit on me like this to....i was driving and it sputtered and died....switched coils it ran for 10 seconds sputtered and died again....now it wont start my wires cap rotor and plugs are newer i changed the coil and crank sensor still nothing
Old Nov 13, 2011 | 05:12 PM
Check and see what you are missing. Are you getting spark? Got fuel pressure? Power at the coil/injectors? Getting injector pulse?
Old Nov 14, 2011 | 06:48 AM
zcrashz's Avatar
zcrashz
I am getting spark from the coil to distributor, but not out of distributor. Got fuel pressure and i can hear pump clicking on when i turn key on. How do I check injector pulse?
Old Nov 14, 2011 | 03:45 PM
zman17's Avatar
zman17
I suggest you inspect the cap and rotor.
Old Nov 14, 2011 | 06:44 PM
If you are losing spark, yeah, find out why first.
