Does My 96 Ram 1500 have Remote Door Locks?
Old Nov 15, 2011 | 09:45 PM
reconrey's Avatar
reconrey
Originally Posted by chadhager03
Is it a little button on the end of a string type thing? If you push that once (or hold it) it's supposed to activate or deactivate the remote abilities. I'd try that first and those remotes look really old, I hope you can get them working
I tried messing with that button, it didn't seem to do anything.
Originally Posted by gdstock
I would google to find Viper website and see if they have support or download instructions tab....Should be something there I would think.
I tried that but I can't figure out what version it is....
Thanks.
Old Nov 15, 2011 | 09:58 PM
gdstock's Avatar
gdstock
Try this: http://www.directeddealers.com/manua...106V_08-04.pdf
Old Nov 15, 2011 | 10:05 PM
reconrey's Avatar
reconrey
I don't think that that's the same one, and it doesn't seem to say anything about reprogramming it.
Thanks.
Old Nov 15, 2011 | 10:15 PM
gdstock's Avatar
gdstock
Thanks.
I thinks someone said Best Buy is a Viper Dealer. Maybe they ahve access to that info. Worth a try I would think.
Old Nov 15, 2011 | 10:32 PM
reconrey's Avatar
reconrey
Hmm, maybe I'll go down there tomorrow.
Old Nov 15, 2011 | 10:38 PM
NyghtProwler's Avatar
NyghtProwler
The FCC ID is the model number I believe..(467)...and the 800 number above that is Vipers telephone.....give them a call....maybe they will send a manual via email???
Old Nov 16, 2011 | 06:45 PM
reconrey's Avatar
reconrey
Odd, I found the viper website and there seems to be a guide for all the remotes, but I cant find 467...?
http://www.viper.com/Support/
Thanks
Old Nov 16, 2011 | 08:42 PM
gdstock's Avatar
gdstock
Thanks
I think I recall you stating that yours is a 2 button remote. I would look on site for any 2 button and try that procedure. Several attempts may be required, but you never know. May get lucky.
Old Nov 16, 2011 | 09:27 PM
reconrey's Avatar
reconrey
Well I think I found the right manual. I think its a 120HF, 135HF, or a 140HF - the key-chain and manuals for those all look the same, but I can't seem to find anything about reprogramming it.
http://www.directeddealers.com/manua...ner_00C_up.pdf
I also found this link: http://www.drdetailshop.com/remoteprogram.html that is supposed to be how it gets reprogrammed, but I tried it multiple times and it didn't work, so I was thinking; could there be a cut wire or broken fuse somewhere?
Thanks.
Old Nov 16, 2011 | 09:33 PM
gdstock's Avatar
gdstock
Thanks.
Could be wire or fuse. I have a saying, "some people should not be allowed to work on stuff..." beacuse they do poor work, especially some electrical work. Can you find the receiver? Trace back where it was wired in and have to check the entire circuit. Hopefully, PO did a good job or had it professionally installed, and did not pull it out of truck.
I wouldn't even know where to begin to look for receiver. May start under dash by steering column.
