1989 318 - 360 swap PLEASE HELP
Old Nov 15, 2011 | 04:44 PM
ericbraden12's Avatar
ericbraden12
Default 1989 318 - 360 swap PLEASE HELP
i recently inherited my grandfathers old truck its a 1989 dodge 318 and i put a 360 which was out of a 1991 well i got it running it revs great siting still if you try to pull out it runs like a nightmare you can floor it and itll take off feels ok not what it should be tho mid peddle it back fires and so and wont hardly run ....i timming it at 10 deg any ideas on what else to check i replaced the pick up coil and injecters with no difference any advise would be great and greatly appreciated
Old Nov 15, 2011 | 06:27 PM
crazzywolfie's Avatar
crazzywolfie
did you also swap computers? is that 10* btdc or atdc.
Old Nov 15, 2011 | 07:36 PM
ericbraden12
btdc and yes i tried both computers didnt change anything
Old Nov 15, 2011 | 08:01 PM
crazzywolfie
does it ever get any better if you mess with the timing? with how old it is the timing chain could be stretched. the old tbi trucks are not very powerful and are impossible to mod for power unless converted to obd2 or carb.
Old Nov 16, 2011 | 11:09 AM
ericbraden12
no messing with the timing didn't seem to help either ...when you drive this thing very little throttle or wide open it runs decent but its mostly mid peddle it don't wanna run period it starts back firing and sputtering but in park it revs up great .....i changed the O2 sensor the one for the 360 plug in was diffident i had to use one for a 318 so all the sensors are for a 318 and the computer that is on it now is the factory 318 computer also if ,didnt know if any of that matters
Old Nov 16, 2011 | 03:10 PM
gdstock's Avatar
gdstock
Don't know, but cam or crank sensor? What about plug wire routing? Could be crossfiring.
