Fuel Pump Relay
Old Nov 16, 2011 | 07:37 AM
kikidbird's Avatar
kikidbird
Default Fuel Pump Relay
Everytime I turn off my truck, I keep burning the relay. The relay gets hot and burns out. Is this a sign my fuel pump is going bad?
Old Nov 16, 2011 | 09:10 AM
Does the pump keep running after you shut off the truck?
Old Nov 16, 2011 | 10:19 AM
kikidbird's Avatar
kikidbird
I dont think so. When I try to start it, it wont. I have to in a new relay.
Old Nov 16, 2011 | 10:31 AM
Aubrey's Avatar
Aubrey
I've not heard of a bad fuel pump burning out a relay. The fuel pump is downstream from the relay. You should be looking upstream from the relay.
Old Nov 18, 2011 | 12:40 PM
kikidbird's Avatar
kikidbird
I found the problem. My radio fuse has been shorting out. I had put foil paper on the fuse. My wipers, horn, fog lights went first n then the fuel pump relay. Removed foil paper n everything is good.
