Tranny hardline blew. Close call! What kind of line for repair?
Old Nov 20, 2011 | 12:37 AM
gdstock's Avatar
gdstock
Originally Posted by shep28
fluid is red. I will replace the trans lines with steel lines and see what happens. I may have a tiny leak in the rusty brake lines. I will replace those as well. Tomorrow should be 50degrees, Running out of warm weather. I need to move down south.
Do you see a crack in the line? There typically isn't enough pressure to crack these lines. Check fittings at transmission to make sure they are tight.
Old Nov 20, 2011 | 04:00 PM
shep28's Avatar
shep28
Well, the brake and tranny hard lines were so rusty that I will replace all of them. I found a nice southern junker ram that I will swap tranny lines with tomorrow.
Old Nov 20, 2011 | 04:06 PM
gdstock's Avatar
gdstock
Make sure you blow out the lines and maybe flush with brake cleaner and blow again. Don't want to take a chance of any crap in the lines getting into your tranny or brake system.
Old Nov 20, 2011 | 11:26 PM
NCC74656's Avatar
NCC74656
i had a jeep grand Cherokee that came down to hard from a jump into a river and the front passenger side linkage pinched the tranny return line. i realized it when i lost all forward gears, i used some hydraulic tubing from ace hardware and 2 compression fittings. total cost in parts was about 3 bucks. i cut out the damaged line and put in the new, never had an issue with it.
