Cracked Dash Replacement (Busted more than Cracked)
Old Nov 22, 2011 | 09:49 PM
  #31
gdstock's Avatar
gdstock
Originally Posted by 2x1972
Looks like you might have to repaint the lower dash assembly to get perfect match?
I'll paint it when I do carpet and seats. It appears to be faded from the sun. It was multi colored before, and passenger side is lighter than driver's side. I used the airbag contol cover for paint match....had to choose one of the three colors and figured that had less damage from sun.
Old Nov 22, 2011 | 10:15 PM
  #32
Wombat Ranger's Avatar
Wombat Ranger
Ahh gotcha. Well it sounds like you are doing a good job and being thorough, keep up the good work!
Old Nov 22, 2011 | 10:30 PM
  #33
gdstock's Avatar
gdstock
Lower part of dash will be easier with a small touch up spray gun. Carpet and seats out minimizes masking. Thought about pulling it all out, but lots of extra work including all the wiring, removal of steering column, etc. May even do it sooner - plenty of time off during next couple of holidays if weather permits.
Old Nov 22, 2011 | 10:37 PM
  #34
Wombat Ranger
I just pulled a lower assembly out of a JY (got lucky and found a perfect one), and it only took about 45 min. The ducting is the real pain.
Old Nov 23, 2011 | 08:24 AM
  #35
Gary-L's Avatar
Gary-L
Veteran: Navy
Looks great. You should call the supplier and let them know that one hole was off.
Old Nov 27, 2011 | 07:17 PM
  #36
Obiejuankinobie's Avatar
Obiejuankinobie
Thanks for your post. I had no issues with my dash. Until I slammed on the brakes and my Golden Retriever bounced of the front of the dash. Long crack developed. Then 6mo later a taxi hit me in 13` degrees below zero and now I have a nice size hole that looks like a pool table racking triangle.
Old Nov 27, 2011 | 07:25 PM
  #37
stewie01's Avatar
stewie01
I've got a few holes like that. My dash is cracked pretty good. It had a blue carpet pad on it when I got it, got sick of it and took it off. The exposure to the sun hasn't helped much.....
Old Nov 27, 2011 | 07:26 PM
  #38
gdstock's Avatar
gdstock
Obiejuankinobie, if you can glue it back together somewhat for support, a dash skin would be easier (and cheaper) to install and silicone to existing dash. Mine looked like a grenade wnet off with very little left, leaving me little option except full replacement. My greatest concern during the process was hoping not to break anything else made out of that crap plastic.
Old Dec 24, 2011 | 12:42 PM
  #39
de8212's Avatar
de8212
Great job. Looks very nice now. i'm jealous. Mine is busted up just like yours was. I have heard how hard of a job this is and I just don't know if I can do it.
Old Dec 24, 2011 | 07:15 PM
  #40
gdstock's Avatar
gdstock
Not really that hard. I only loosened anr rolled dash frame back. New piece fit well with no trimming required.
