Fog light issue
Old Nov 21, 2011 | 03:20 AM
GiantsNiners99's Avatar
GiantsNiners99
Default Fog light issue
On my 99 sport, when i pull the **** for the fog lights they dont turn on. But when i pull just a little bit harder they work just fine until i let go (they turn back off). What can i do to make it so they work normal? When they turn on i can hear the click in the fuse box. Thanks for the info.
Old Nov 21, 2011 | 04:04 AM
J415's Avatar
J415
Sounds to me like it might be a faulty switch. These are stock lights correct?
Old Nov 21, 2011 | 04:10 AM
GiantsNiners99
Correct. Stock Fog lights.
Old Nov 21, 2011 | 06:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace the switch.
Old Nov 21, 2011 | 09:01 AM
Archion's Avatar
Archion
I picked one up from Advance for like 45 bucks, works fine. The PO had chopped off the OEM fog lights because he couldnt figure out that it had a bad switch. I just got done wiring them back in.
Old Nov 21, 2011 | 11:02 AM
Cheat's Avatar
Cheat
The switch is bad, Ive had this same issue with my truck, You can either attempt to take the switch apart and repair it (unreliable) Or buy a new one. If you let this go on, It can become much worse. Ive had mine drop out while going down the road at random. All lights. Gone. Not fun at all.
-Cheat.
Old Nov 21, 2011 | 11:28 AM
Wombat Ranger's Avatar
Wombat Ranger
Used to happen to me sometimes in my yellow '72 d100. I just got used to it, i got real good at jigglin that switch too
Old Nov 21, 2011 | 11:47 AM
J415's Avatar
J415
If you want to pick one up from the bone yard, the Richmond pick n pull has atleast 5 '98 and up Rams you can take a look at. Just a friendly heads up.
