Old Aug 13, 2015, 08:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
cab lights
Old Nov 21, 2011 | 10:52 AM
DoubleL24's Avatar
DoubleL24
Default cab lights
I have a 99 ram ext cab and I wanna put cab lights on it and I know there's a write up in the DIYs but has anyone done it to an ext cab? Is it pretty much same process? Do I have to take anything off in the back for headliner to come out?
Old Nov 21, 2011 | 10:57 AM
Cheat's Avatar
Cheat
From what I can tell in my truck all you would need to do is remove some more plastic. Just enough to get the headliner down. When its down its all the same thing, Just some advice though. Use relays on this project. Do NOT connect dirrectly to the switch. IMHO this is very dangerous to do because our switches are already weak as it is. Putting more strain on them doesnt help.
-Cheat.
Old Nov 21, 2011 | 12:22 PM
rumble_truck's Avatar
rumble_truck
I did clearance lights on mine, there's a template stamped into the roof you can use. I ended up running my own wire/switch because i'm not the best at reading a wiring diagram to wire the light to show up with my running lights. (there is a strange connector hanging out of my A pillar on both sides thats always hot when the trucks on, so I used that as power along with inline fuse.
Old Nov 21, 2011 | 12:36 PM
gdstock's Avatar
gdstock
+1 on the relay idea. Control to relay can come off headlight switch so those lights are only on with park or head lights.
Old Nov 21, 2011 | 03:01 PM
biggreen2500's Avatar
biggreen2500
i got a 01 2500 i put Recon Led cab lights on my truck i have 10 of them... i hooked it right to the head light switch and its been going good for 3 years
Old Nov 21, 2011 | 03:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I have the complete setup out of my 98. If anyone is interested. Lights, clips for harness and complete wire harness.
Old Nov 21, 2011 | 03:19 PM
Wombat Ranger's Avatar
Wombat Ranger
PM sent
Old Nov 22, 2011 | 01:05 AM
biggreen2500
i also have a stock set of cab lights of a 98 as well all 5 lights srcrews clips and wiring harness... too i'd sell cheap
Old Nov 22, 2011 | 09:42 AM
Cheat's Avatar
Cheat
Right, Led lights. They only pull ~.1 of a amp. Not enough to harm the switch. Regular lights will pull more and will harm, And IMHO leds or not I would rather be safe than sorry. 6$ more and a little more wiring for some more peace of mind? Hell yea im gonna do that.
-Cheat.
