Wiring Help (radio, dome lights)
Old Nov 23, 2011 | 07:38 PM
mrbubblemaker's Avatar
mrbubblemaker
My 95 radio is on connector A
Old Nov 23, 2011 | 07:40 PM
gdstock's Avatar
gdstock
Ignition Off Draw.
OR....
Acronym
Definition
IOD
Institute of Directors
IOD
Information on Demand
IOD
International One Design (sailing)
IOD
Institute on Disability (University of New Hampshire)
IOD
Indian Ocean Dipole (climate mode)
IOD
Integrative Oceanography Division (La Jolla, CA)
IOD
Integrated Optical Density
IOD
Information Object Definition
IOD
Injured on Duty
IOD
Identified Outward Dialing
IOD
Iron Overload Diseases
IOD
Issue Of Data
IOD
Ignition Off-Draw (automotive)
IOD
Image Online Design, Inc.
IOD
Image on Demand
IOD
Input/Output Device
IOD
Intelligent Output Driver (Adiabatic Logic Ltd)
IOD
Install on Demand (Microsoft)
IOD
Index of Deprivation
IOD
Irrevocable Offer of Dedication
IoD
Isle of Dawn (gaming)
IOD
Index of Distribution
IoD
Isle of Dread (gaming)
IOD
Institute Of Diving
IOD
Insurance on Demand
IOD
Interest on Deposit
IOD
International Operations Division
IOD
Information of Delivery
IOD
Integrated Observation Device
IOD
Insurance Operations Department (PBGC)
IOD
Initialing Outfitting Directive
IOD
International Order of DeMolay
IOD
Intercompany Operations Director
IOD
Installation of Officers Dinner
IOD
Interactive Organizational Directory
Old Dec 4, 2011 | 07:32 PM
Fifthwheelin's Avatar
Fifthwheelin
OK, So I replaced the IOD fuse and all was good. Until I went to start the truck todat (to go get a christmas tree). The battery was DEAD dead. I boosted it and got her running.
I've now got it parked with the IOD fuse out so it wont draw down. I checked current with the key out and the IOD circuit was drawing 3.1 mA. Not a lot but something.
Also noticed with the IOD fuse installed, and a new fusible link under the hood for the blinkers, the blinkers work with the key out of the ignition. I know thats not supposed to happen.
I have a new ignition switch not yet installed, is this a common part to fail, and has it been known to fail in the "on" position? I bought it because the radio used to not turn off, but after all this, the radio turns off on as it should, and the current on that fuse with key off is zero.
Old Dec 4, 2011 | 07:47 PM
3.1ma is fine. That's prolly 'keepalive' power for radio, and pcm memory.
What are the odds that one of the relays stuck, and left something on?
Old Dec 4, 2011 | 08:15 PM
Fifthwheelin
Its possible. Remember that my issues started with an intermittent problem, resulted in a blown fuse, that means the fuse got HOT, hot enough to melt, and also hot enough to blown the blinker fusible link, so welding some contacts in a relay together is possible under those circumstances.
I really need a FSM for this thing, was using the 96 posted online, but apparently that is not acurate for 99 wiring. If I could trace the circuit I could nail the problem. Will ahve to check ebay for one.
Old Dec 4, 2011 | 08:40 PM
gdstock's Avatar
gdstock
Get the 2001 FSM. I have a 1999 and everything seems to match my truck.
Old Feb 26, 2012 | 07:54 PM
Fifthwheelin
UPDATE: Its been a long while, and I've been pulling the IOD fuse each time I park the truck, which is annoying to say the least. Anyways, its dark out all the time now and I finally noticed that the Halo light around the key is staying on.
I have a new ignition switch, still not installed, so I hope that will fix the problem. For the life of me I can not find the seciton of the 2001 FSM that shows the wiring to this bulb. Anyone?
Old Feb 27, 2012 | 11:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace door jamb switches yet? I think they would be related to the light at the ignition switch. And, IIRC it's a pink wire that goes to that bulb. My 2000 does not have that wire or the halo lite. My 98 did. And at one point I tried to swap switches, but the wiring simply was not there.
Old Feb 27, 2012 | 01:08 PM
xjarhead69's Avatar
xjarhead69
From the 96 FSM:
KEY-IN-SWITCH/HALO LAMP
C213
CAV CIRCUIT FUNCTION
1 G16 22BK/LB LEFT FRONT DOOR JAMB SWITCH SENSE
2 626 18LB KEY-IN IGNITION SWITCH SENSE
3 Z3 20BK/0R GROUND
4 M50 22YL/RD KEY-IN LAMP DRIVER
At least unplug the door jamb switch to see if that helps.
Dave
Old Mar 20, 2012 | 09:49 PM
silverlakexj's Avatar
silverlakexj
I'm so glad I found this thread. When I bought my 96, the radio stayed on all the time unless you manually shut it off (aftermarket one). It annoyed me, so I pulled it and someone had run a jump wire from the power outlet power wire and joined it with the constant and running power wires for the radio. I thought they were stupid, and wired it the right way. Didn't work!! and I lost my interior lights, mirrors, and light under the hood. I tried wiring put it back together with the jump wire, and wired it with only the constant wires for the radio, and everything is back to working as it should.
So now I'm going to check the IOD fuse, I didn't think to check this at the time. Is there anyway that this is related to the ignition wiring recall?
