Wiring Help (radio, dome lights)
Old 11-11-2012 | 05:12 PM
Fifthwheelin's Avatar
Fifthwheelin
ok, so its been almost a year since I started this thread. Time for an update.
I'm Really sick of Finding a dead battery if I let the truck sit for more than a day. Its not a vehicle I use often except this time of year.
So I busted out the multiemter, soldering iron, wire, and a 10 amp fuse. I soldered up some long wires with crimp connectors on one end and the 10 amp fuse on the other. Armed with my new Ampmeter connected to the IOD slot, I found 0.5A draw when KEY OFF. No wonder the battery is dead all the time.
I pulled out the FSM wiring diagrams and looked at the IOD distribution, then I went to town on the dash removal. I pulle the connectors off the back of the fuse panel until I found the one that was drawing power. It was C2.
This feeds the under hood light, and flashers. I pulled each pin out of the plug and found that only the big red/blk was causing the issue. Wierd. So I started plugging in the IOD fuse and pulling it out, hearing Relay clicks I found that the drivers seat clicks.
Under the drivers seat there is a 10 pin connector. I dont have heated seats or power seats. The pink wire from this connector is corroded. Removing it from the connector sheds 4/10 of the current draw. Unplugging the connector completly sheds the parasitic load.
Unfortunatly the 2001 FSM does not detail this connector. I now need help figuring out how to trace these wires to find the issue and remove it. Does anyone know what this 10 pin plug feeds? specifically the pink wire.
Quick Reply: Wiring Help (radio, dome lights)
