catalytic converter question
Old Nov 21, 2011 | 05:10 PM
Z.rawk95's Avatar
Z.rawk95
Default catalytic converter question
How much of an effect does the cat have on how loud exhaust is? I put a glasspack on my truck saturday and i cranked it up while it had no muffler and it wasnt very loud. Does the cat make it very much quieter and when I take it off in the future will it be noticably louder?
Old Nov 21, 2011 | 06:13 PM
Ramcountryboy's Avatar
Ramcountryboy
Yeah a stock cat makes the machine quite a bit quieter from my experience. I had my pickup straight piped with just the cat and when I removed the cat (plugged up on me) it was WAY louder, like figure 8 race car loud. I replaced it with a magnaflow cat and its quieter than with nothing but noticeably louder compared the stock one. Seems the stock cats muffle the sound alot
Old Nov 21, 2011 | 06:42 PM
dogin fathers ramindaughters's Avatar
have no cat on my truck with TRUE duals run on it with glasspacks for a muffler and it is LOUD it sounds really good and it will rattle the windows in houses and other cars. ( by the way I also have mine run straight out the back with 3" or 3 1/2" chrome slant cut tips sounds GOOOOOOOD
Old Nov 21, 2011 | 08:15 PM
dipsherry's Avatar
dipsherry
yeah the cat affects sound. More so than a muffler IMO my old truck with stock cat and cat back was still quiet. then i went to magnaflow direct fit cat.. a lil louder but when i went to the off road y pipe i got the sound i wanted it was good at a cruise but when u laid into the skinny pedal you knew it
Old Nov 21, 2011 | 08:27 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I would so pull an Eddy Murphy banana on you. May just upgrade to potatoes.
You're the kind of person deserving of a citation for stupid **** like that given how inconsiderate you are to young kids' ears as well as elderly.
JM effin' O though
Old Nov 21, 2011 | 11:13 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Pardon my manners. To answer your question, yes a Cat has an effect on the exhaust volume in addition to other components of the system.
Here is a picture of the cat that does all the chemical schtuff (for lack of technical terms).
By visual inspection, all the exhaust fumes pass through that contraption. If it were not there or shall we say a big friggin hole the diameter of the exhaust system, then what do you think the effect on sound would be?
Old Nov 22, 2011 | 08:55 PM
Wh1t3Nukle FYI im not inconsiderate of young or elderly thats why I dont romp and stomp my truck when around alot of other people I have rattled the windows in my own house setting in the drive way and rattled my friends other vehicles windows either passing them or playing around. If you drive like you have some since then its not that bad you can for sure tell that it has duals on it but yes you go romping it and it is load.
Old Nov 24, 2011 | 10:26 AM
Z.rawk95's Avatar
Z.rawk95
What is the in/out dia. on the cat as well as the length?
Old Nov 24, 2011 | 11:02 AM
redneck_ram's Avatar
redneck_ram
my truck is noticably louder with a gutted cat compared to having one. im running the stock setup with a glasspack in place of the muffler.
Old Nov 25, 2011 | 04:37 PM
Matt Nickerson's Avatar
Matt Nickerson
exhaust diagrams:
https://dodgeforum.com/forum/2nd-gen...ram-1500s.html
94-99 cat is dual 2" in, single 2.5" out
00-01 cat is single 3" in, single 3" out <----This is yours
Not sure on length...If you're looking to buy a cat online all you have to do is type in your vehicle info on the website (summitracing, jegs, rockauto, etc.) and they'll search for the correct cat for you. So no need to worry about the sizes.
I got the y-pipe with a cat from Eastern (on rockauto.com) for $230 and just bolted the y-pipe on and clamped the cat to the y-pipe. You can go that route or just buy a dual 2" inlet cat from magnaflow (~$100) and have a muffler shop weld it to your stock pipes.
