Gah! One thing after another.
Old Nov 22, 2011 | 06:21 PM
SweetTooth's Avatar
SweetTooth
Check all electrical connections from the battery, to the starter first. Make sure they are all clean and tight.
If that doesn't help, swap the horn relay, and the starter relay in the PDC. You can also try swapping the fuel pump relay for another one, and see if that makes any difference.
this is my IAC, this is the cleanest it will get. I used the TB and carb cleaner. I did my best.
-If I can keep the truck running by applying gas, that wouldn't have anything to do with a Fuel Pump would it?
Should I replace IAC or would it even matter?
I'm not very smart on vehicles, but I'm learning.
Old Nov 22, 2011 | 06:36 PM
UnregisteredUser's Avatar
UnregisteredUser
It'd be an indication that the pump is working, at least to some extent. I'd put a fuel pressure test gauge to it just to be sure.
Looking like that? Yeah, I'd replace it.
A sticking IAC can definitely cause your engine to die at idle. It's the most commonly complained of symptom when an IAC fails.
Old Nov 22, 2011 | 06:41 PM
SweetTooth's Avatar
SweetTooth
Alright, I will be replacing it soon.
Are there any other sensors that I should look at if it needs to be replaced
Old Nov 22, 2011 | 08:08 PM
gdstock's Avatar
gdstock
Before you go and spend a lot of money on sensors (other than IAC) checking fuel pressure to either rule that out or confirm that it is a problem would be a great start. If it fails to get enough fuel, it will not run right, die, etc.
Old Nov 22, 2011 | 08:30 PM
SweetTooth's Avatar
SweetTooth
Alright, I just purchased a IAC I will be replacing it thursday, I will see if that fixes my issue.
Can anyone recommend me a Fuel pressure gauge if I have to check it.
Old Nov 22, 2011 | 08:54 PM
UnregisteredUser
Most auto parts stores offer them for rent.
Old Nov 22, 2011 | 11:06 PM
jswain's Avatar
jswain
Don't forget the battery / connections. Like others have said, the clicking with no start sounds like a bad/loose/corroded connection.
Old Nov 23, 2011 | 07:09 AM
Novarider's Avatar
Novarider
Have you had the battery tested to make sure it's still good?
