Fuel pump !!??
Old Nov 25, 2011 | 01:15 AM
brian_87's Avatar
brian_87
Unhappy Fuel pump !!??
Hey guys i got a 98 ram 4x4 v8 5.9l magnum i was driving home today and all of a sudden my truck started coughing and farting. So i was thinking it was a fouled plug due to my plenum plate issue. I still need to install the aluminum one i have. But i replaced the plugs they were pretty bad but even after install it still lacked power and when fully on the gas it hesitates feels like it wants to go but it cant. It drives alright if your not on the gas to much but it revs up no problem when its parked . I also have noticed that my fuel gage has been bouncing around alot for a couple weeks first full then empty then quarter tank. And also while i was reving it in park the fuel pump got loud making a high pitched noise which i have never noticed before. so does anyone know what this could be im pretty sure its the fuel pump but i deffintley wanna make sure before i just go out and buy one. I found one thru lordco and they want 700$!!!!!! ... I also found one on ebay for 119$ so i think ill be getting it from there lol if its needed.. Thanks...Brian
Old Nov 25, 2011 | 01:20 AM
brian_87's Avatar
brian_87
Also there is no cat in it so it couldnt be plugged lol
Old Nov 25, 2011 | 01:55 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
How about checking the fuel pressure?
Read this thread to where they mention the fuel pressure.
Old Nov 25, 2011 | 09:17 AM
silverlakexj's Avatar
silverlakexj
Napa has them for around $200. I know my brother and dad have had to replace there pumps around 196000 to 198000 miles.
Old Nov 25, 2011 | 10:35 AM
merc225hp's Avatar
merc225hp
Lordco price is $400, Napa is $330(mech price), Dealer was $450. I would not buy one off e bay. I have a used one you can buy. PM me if you would like it.
Old Nov 25, 2011 | 03:51 PM
gdstock's Avatar
gdstock
+1 on what Wh1t3Nukle said. How about checking fuel pressure?
If fuel pump is bad or going bad, it can be confirmed in 5 minutes by testing fuel pressure. Doesn't make sense to start swapping parts (expecialy expensive parts) to solve a problem that you have not poistively identified.
Test fuel pressure. Should be around 50 pounds. If that is good, your problem is elsewhere, but I would suggest starting here.
Old Nov 26, 2011 | 12:25 PM
brian_87's Avatar
brian_87
its the pump i went for a drive yesterday and alost didnt make it home the pump is making a very high pitch grinding noise now. i ordered one off ebay its a Airtex E7138M AC Delco MU2046 Delphi FG0227
now i just gotta wait on it i did try lordco they could only bring in the one they had for 770$. and i think im just going to take the box off to do it and maybe do a body lift at the same time thanks for the help tho boyzzz
Old Nov 26, 2011 | 12:29 PM
Which manufacturer is it? Airtex doesn't have a really good rep, Delco and Delphi units should last longer than the truck.
Old Nov 26, 2011 | 12:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's all three in one! LOL
Old Nov 26, 2011 | 01:09 PM
Aircophi?
