band adjustment 46re
Old Nov 27, 2011 | 12:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Augiedoggy
it a TORX bit...sometimes called a star bit.... Chrysler /jeep dodge has been using them for over a decade now....
I'm adjusting my bands today also to eliminat any of the easy stuff before taking it to a shop where the answer is almost always "You need a rebuild".
They are not all Torx. But you might find that out when you go to adjust them today.
Old Nov 27, 2011 | 09:59 PM
Augiedoggy's Avatar
Augiedoggy
He asked what a "Torque head" was and I just tried clarify it for him...
Thanks to incorrect directions I never got that far...the "1/4" square head bolt for the rear band adjustment I read about is actually a 5/16 square head it seems and I didnt have the right socket to do the job today...
Old Nov 27, 2011 | 10:21 PM
aim4squirrels's Avatar
aim4squirrels
Do not confuse ft/lbs with in/lbs or you'll be in for a bad day.
Old Nov 28, 2011 | 07:37 AM
zman17's Avatar
zman17
I used a 5/16 open end and a 5/16 allen 3/8 drive to connect to torque wrench. And then adjusted screw according to the manual when using the special wrench.
Old Nov 28, 2011 | 07:56 AM
kd5taa's Avatar
kd5taa
Originally Posted by mj23polaris
(5) Hold adjuster screw in position and tighten
locknut to 41 N·m (30 ft. lbs.) torque.
so i loosen the nut, i tighten the torque head to 72lbs then back the nut off again then tighten the the torque head again another 30lbs? jus wanna make sure i do this RIGHT haha
No man, torque the head to 72 INCH pounds, back it off the required amount of turns then hold it right where it is while you torque the locknut to 30 FOOT pounds
Old Nov 28, 2011 | 07:57 AM
Augiedoggy's Avatar
Augiedoggy
I will give that a shot thanks.... is there supposed to be any play behind the screw? mine had play and I could rock the arm a bit and I just removed the loose play yesterday and now its really misbehaving by clunking into drive or reverse from park I drove it like 50 ft and decided to park it since it didnt seem to move well...
I only ask because even after the 2 7?8 turns back ward from 70lbs pressure I wouldnt thing it would be loose?
Old Nov 28, 2011 | 12:52 PM
Augiedoggy's Avatar
Augiedoggy
wow glad I saw this before reattempting this today..
Old Nov 28, 2011 | 12:55 PM
zman17's Avatar
zman17
Yes, the arm will be loose. And that's where I remember MonteC saying to back it off 2 turns. Actually, I think it was in a thread by AIM.
Old Aug 12, 2021 | 07:17 PM
Terry660's Avatar
Terry660
It calls for an 8mm 4 point sockets for rear band. I'm stuck. I have no 4 point and I live in middle of nowhere with closest auto parts is napa... help
Old Aug 13, 2021 | 01:19 AM
master tech's Avatar
master tech
Site Moderator & Tech
You don't need a 4 point socket. To adjust the front band you will need a 3/4 or 19 mm socket and either a torque socket or 5/16 or 8 mm socket. Adjust the band to where you have 1/2 inch of free play and tighten the 3/4 nut and check you free play. The rear band may have a 18mm socket or 19mm / 3/4. Adjust the rear band the same way. You don't need a torque wrench to perform the adjustments. I'm a retired transmission tech with 30 year with the product.
