O-ring for water pump tube
Old Nov 27, 2011 | 01:45 PM
I used a burr to flare the hole a bit, but, just on the top edge. Oring inserts nicely, and doesn't get trashed on installation.
Old Nov 27, 2011 | 08:53 PM
BigBlue83's Avatar
BigBlue83
i was doing doing my timing chain gasket and changed my water pump and heard of others having issues so i whent to autozone and they had this two dollar box of O-rings there was 16 O-rings some the same sizes but a wide range of sizes i put two on mine than hit it up with some RTV as well
Old Nov 28, 2011 | 12:00 AM
poorboy2's Avatar
poorboy2
I replaced my waterpump recently and I deburred the edge of the hole first then a light coating of petroleum jelly and installed the tube and O ring. Then, to be sure, I cleaned the area and put a light coating of high temp. RTV. Just hope I never have to replace it again.
Old Nov 28, 2011 | 05:57 PM
plott hound's Avatar
plott hound
Thumbs up
just took the truck for a spin to burp the cooling system and i have no leaks.looks like the old silicone on the 0 ring trick did the job.thanks guys.
Old Nov 28, 2011 | 08:00 PM
gdstock's Avatar
gdstock
Glad it worked. Doesn't it just grind when a simple thing causes so much trouble. Makes me pull my thinning hari...lol
Old Nov 28, 2011 | 09:13 PM
plott hound
Thumbs up
you got that right gdstock.done the same job before with no hassles then this happens.damn thing gave me 40 fits,then i thought i had a major problem.water pump made some nasty groans till i got the air purged out of it.
