Power Mirror Fuse Question
Old Nov 27, 2011 | 05:45 PM
Wiring diagrams are usually a good place to start. That's where I found it.
Old Nov 27, 2011 | 05:59 PM
stewie01's Avatar
stewie01
Ah. I did look at the wiring diagrams, at the being of the section, and got really confused.
Old May 7, 2013 | 04:03 PM
ClarkGustafson's Avatar
ClarkGustafson
I searched and now I am resurrecting! I have same issue, just purchased the truck, heated/electric mirrors are intact. Heat button lights up when pressed don't know if it's actually warming mirrors, but the mirror controller does nothing. I pulled the door panel and they are plugged in. The power windows/door locks work great; no burned fuses I could find. I am at a loss...any help is greatly appreciated.
Old May 7, 2013 | 08:11 PM
stewie01's Avatar
stewie01
Let me know if you find a solution. Mine have since quit working too.
Old May 8, 2013 | 12:28 PM
Make sure you are getting power to the switch.
Old Jan 30, 2014 | 12:11 PM
Jigabop's Avatar
Jigabop
*bump*
my damn mirrors only work in 1 direction
both sides will turn inward towards the cab, but wont respond to any other direction.
so for the passenger mirror, that is left on the stick, and on the driver mirror that is right on the stick.. they don't respond to up or down, or the outward direction... heat works fine though, and turning inward works fine.
Old Jan 30, 2014 | 01:08 PM
Bad switch?
Old Jan 31, 2014 | 12:45 PM
Jigabop's Avatar
Jigabop
indeed. played with it last night and found that if I push on the switch while moving the stick in a direction, they work in all directions! but I have to push in on the damn thing for it to work right...so new control switch oughta fix it right up
Old Jan 30, 2024 | 04:54 PM
Blondebat's Avatar
Blondebat
Default 2002 2500hd mirror fuse location
01 factory service manual. Sometimes its a real trick to extract secrets from the damn manual. I just have a GREAT deal of experience.
Is it fuse 01 or on page 01 of manual?
Old Jan 30, 2024 | 05:32 PM
That would be the 2001 service manual. Don't think we have 2002....
