4x4 issue
Old Nov 29, 2011 | 02:21 PM
sportyboy04's Avatar
sportyboy04
New Member
Default 4x4 issue
ok, read a lot of threads on this but still no answer... I have a 200 ram sport 1500, bought it transfer case was junk, replaced it, trans case seems to work fine but, hubs not engaging.... replaced actuator & switch, vacuum seems fine switches @ actuator, but still not engaging...
any thoughts would be helpful, also, what if, and is it possible, someone put the fork in backwards?????
thanks
d
Old Nov 29, 2011 | 02:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is this http://www.dodgeram.org/tech/repair/..._engagment.htm and also make sure there are no burs on either shaft. And the shoes on the fork could very well be worn.
Old Nov 29, 2011 | 02:32 PM
sportyboy04
New Member
thanx zman... already been through all that.... vacuum is good, dont feel anything happening or hear anything when going through transfercase gears, like it's not even trying to engage.....
Old Nov 29, 2011 | 03:17 PM
dlyter09's Avatar
dlyter09
Im not sure what your problem is. You say the hubs arent engaging but then you say the tranfer case doesnt try to engage. Have you tried to manually shift the transfer case from underneath? Im a little confused maybe you can clarify this a little more..
Old Nov 29, 2011 | 03:38 PM
sportyboy04
New Member
Default vaccum actuator
k, transfer case is engaging but hubs arn't locking... rep, actuator & switch, have vac and seems like plent down at vacum actuator but hubs arnt locking..... possible someone put fork in backwards????
Old Nov 29, 2011 | 03:41 PM
dlyter09's Avatar
dlyter09
Im not sure if its possible for it to be installed backwards or not. You can pull it all off the axle and have a look. Maybe there isnt enough vacumm.
Old Nov 29, 2011 | 04:06 PM
sportyboy04
New Member
running out of answers.... soon it's off to shop
Old Nov 29, 2011 | 07:40 PM
Terribly's Avatar
Terribly
I had to replace my actuator gasket a few years back and if I remember correctly, it looked like it could be installed without the fork even on the collar to engage the axle. 5 min. check.... 4 bolts and a $2 gasket to find out.
Also, a few months back I had a truck come into our shop that had the front pumpkin hollowed out by the previous owner. No gears, axles or U joints. The new owner had no idea why the truck wouldnt engage tho!
