Are all Magnum 318's the same?
Old Dec 2, 2011 | 01:33 PM
dodgetruck2's Avatar
dodgetruck2
Default Are all Magnum 318's the same?
I am trying to sell the 318 out of my 92 dakota (sig) and a guy is interested and wants to know if it will work in his 99 1500. Will it work or is there going to be to many differences?
Old Dec 2, 2011 | 03:22 PM
Hahns5.2's Avatar
Hahns5.2
The long block is the same. The passenger exhaust manifold and intake manifold are different (EGR), the throttle body is different, the injectors are different and all the sensors are different. But it can all be easily swapped.
Old Dec 2, 2011 | 04:04 PM
Annihilator_X9's Avatar
Annihilator_X9
Basically he will have to swap his parts onto your block.
Old Dec 2, 2011 | 04:20 PM
dodgetruck2
So if he swapped computers would he be fine or would the tranny computer not wana talk to it?
Old Dec 2, 2011 | 04:45 PM
He would be better off swapping his stuff onto your engine. MUCH easier.
Old Dec 2, 2011 | 04:48 PM
BigBlue83's Avatar
BigBlue83
How can you tell if you have a 318 or the 360 magnum???
Old Dec 2, 2011 | 04:49 PM
Casting numbers in the block. Usually on the rear deck surface, behind the drivers side head, right where there are ten million things in the way, so, you can't possibly see it. Should also be some casting numbers in the side of the block.
Old Dec 2, 2011 | 04:55 PM
Silver_Dodge's Avatar
Silver_Dodge
Another easy way to check is that 360's are externally balanced, 318's internal.
Old Dec 2, 2011 | 06:35 PM
Magnum4406's Avatar
Magnum4406
If you know the vin the engine code is the 8th digit Y-5.2, Z-5.9 (gas)
Old Dec 2, 2011 | 07:29 PM
BigBlue83's Avatar
BigBlue83
Is the 5.2 the 318 and the 360 the 5.9? Or could it be either or
