high beams won't go out
Old Dec 3, 2011 | 05:38 PM
2001sportgirl's Avatar
2001sportgirl
Default high beams won't go out
My truck really is possessed. I was driving down the road, no lights on, and I just happen to glance at the dash and see my high beam light on. So I pull over and to see if they really are on since my headlights switch is in the off position. And the high beams are on. I mess around with the switch and walk around the truck to see which lights are. When the light switch is off, only the highs are on. The rest of the light work fine. So I pull the lever to turn my highs off and nothing. Doesn't do anything but click. Any ideas?
Old Dec 3, 2011 | 07:15 PM
dsertdog56's Avatar
dsertdog56
Could be your headlight switch or colum switch but....
By chance do you or truck reside in or was truck made for Canadian export?
If so, your Drl relay (daytime driving lights) relay may have burnt up...Its usually on the drivers inner fender under the master cylinder. Pull the plug off the relay and your lights will be fine.
Old Dec 3, 2011 | 07:16 PM
gdstock's Avatar
gdstock
I have seen several threads baout this, and several of them were wires shorted due to the switch, but I think that was in older trucks than yours when switch was on dash. You might sear for "high beams stay on" and see if you can find them. Can't recall the fix as I have not yet experienced that problem.
Old Dec 3, 2011 | 09:10 PM
Two or four light system?
Old Dec 4, 2011 | 08:32 AM
DodgeRider1500's Avatar
DodgeRider1500
+1 on what dsertdog56 said, I had a similar problem, try unplugging the plug out and see if you highbeams go out, if they do, chances are that black box is finished. I took 2 pictures showing where it is if you need a point in the right direction.
http://s1132.photobucket.com/albums/...11116-2131.jpg
As mentioned, usually under the master cylinder drivers side inner fender. Good luck!
