Dead battery
Old Dec 5, 2011 | 09:22 AM
jemrick's Avatar
jemrick
Default Dead battery
2001 Ram 1500 5.9l V8. Dead battery again. Alternator seems to be putting out plenty. I have replaced the battery twice. Starts fine for a month or so after replacing batteries. 1st battery was found to be faulty. Now same thing with 2nd battery. Maybe not the batteries. All the connections between alternator and battery are clean and no breaks in wires. Any ideas From the forum? Thanks
Old Dec 5, 2011 | 09:23 AM
Check and see how much of a draw there is on the battery with nothing on. (key out, engine NOT running.) May have a relay that sticks..... leaving something on. (which means, if the problem isn't present when you go looking, you won't find it..... fun huh?)
kadetklapp's Avatar
kadetklapp
Have you had the alternator checked? Does the truck sit a lot?
FWIW, my battery died this morning.....
Old Dec 5, 2011 | 10:12 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Get it all tested for free at a parts store, autozone, etc. If you have AAA, they will also come out and test for you. In addition, replace battery on the spot. You just pay for the battery.
Old Dec 5, 2011 | 06:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the glove box switch isn't broke and the light is not on all the time.
Old Dec 5, 2011 | 07:21 PM
Ugly1's Avatar
Ugly1
What would be considered too much off state current draw on a stock truck?
Old Dec 5, 2011 | 07:24 PM
gdstock's Avatar
gdstock
Just guessing, but should be less than 1 amp. Don't know if that is listed in the FSM or not. I think I'll check.
I have another vehicle that drains battery, but doesn't kill it. (any Jag experts out there?)
Old Dec 5, 2011 | 07:39 PM
jemrick's Avatar
jemrick
Fully charged the battery. Turned over with plenty of crank. Had to pump the gas pedal hard and hold it down to keep it running. If I let off to try to idle truck would just die.
Old Dec 5, 2011 | 07:46 PM
gdstock's Avatar
gdstock
Dirty or malfunctioning IAC will keep it form idling properly.
Old Dec 5, 2011 | 07:48 PM
crazzywolfie's Avatar
crazzywolfie
have you tried removing the o2 sensor? it almost sounds like your cat might be clogged.
