318 missing
Old Dec 15, 2011 | 02:20 PM
  #21
a-hall's Avatar
a-hall
Originally Posted by J415
Make sure that you got the correct plugs in there. It could be that you got the wrong ones. Also, I know people generally tend to think MSD is the "all mighty" when it comes to wires, but they do arc if not routed correctly. Try this just to rule out arcing. get a spray bottle and MIST the cable's. Do this in the dark/semi dark. It will help show if your cable's are arcing or not. Either way, ROUTE YOUR CABLE'S VIA THE TSB!!! Also, I don't know why, but I have a funny feeling that the cat or exhaust is plugged...I'm with you on that one GDSTOCK.
whats gonna plug the exhaust? Carbon buildup? its only a year and a half old. How can i check the cat if it is so called "plugged"? Also i just bought new ntk o2sensors and mopar plugs, mopar rotor button, and mopor cap.
Old Dec 15, 2011 | 02:47 PM
  #22
Remove the pre-cat O2 from the exhaust. You can unplug it, or not, up to you. (I would....) Take it for a drive. Run better? Cat is clogged.
Old Dec 15, 2011 | 06:41 PM
  #23
J415's Avatar
J415
If the cat is clogged, some of that honey comb can lodge itself in the intermediate pipe. Hence, clogged exhaust. When my cat went out on me, part of it got stuck in the tail pipe. Right above the axle where there's a hump in the pipe.
Old Dec 18, 2011 | 02:51 PM
  #24
a-hall's Avatar
a-hall
alright i did some expirementation. Pulled the front o2 sensor. drove the truck. couldnt get the check engine light to flash even tho it was already on. The truck drove fine but was trying to run rich cause i could smell it. Drove back home put o2 sensor back in. Let it cool then droveit again idle was fine and when i got on the gas sure enough i could get the check engine light to flash. came home changed the plugs, dist cap and rotor button, installed new ntk o2 sensors. Old plugs looked great but were all soaked in gasoline. put back in mopar champion plugs and the truck performs flawlessly. No missing at idle or underload. we will see how long it lasts. Also the old o2 sensors looked awful. full of black carbon and therefore i think they were fouling cause the engine to load up on fuel and miss. (hopefully)
Old Dec 18, 2011 | 03:05 PM
  #25
Blown plenum will trash O2s, and cat over time. Have you dealt with that yet?
Old Dec 30, 2011 | 02:43 AM
  #26
a-hall's Avatar
a-hall
Plenum is still good.cat is clean. Truck is doing great. the o2 sensor change did the trick. Everyone thnks for the help
Old Dec 30, 2011 | 11:33 AM
  #27
gdstock's Avatar
gdstock
Pulling tohe O2 sensor will also cause it to run rich and may even dump enought fuel to wet plugs. Just saying....Hope problem is resolved, but if it comes back, I have to agree with cat issue.
