help
Old Dec 6, 2011 | 08:52 PM
abgriffin's Avatar
abgriffin
Default help
have a 1998 dodge ram 5.9l motor.it has 141.000 miles on it.runs great once it starts.you have to turn the key off and on a couple times,then it will start,i can hear the pump when the key is turned on but it acts like it doesn't have enough fuel to start on the first try.does anyone know if this sounds like the fuel pump is going bad.again it runs great once it starts.have tuned up everything else.any help would be appreciated
Old Dec 6, 2011 | 09:04 PM
rbushmx's Avatar
rbushmx
I am having the same problem. I found one of my injectors leaking down. Replaced my o-rings, IAC, PCV,and fuel regulator/filter. This seems to be a common problem.
Old Dec 10, 2011 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Ram section, The members there maybe able to help you.
Old Dec 11, 2011 | 01:02 AM
Ramcountryboy's Avatar
Ramcountryboy
+1 on the fuel pressure regulator/filter. Mine has the same problem, after it sits the fuel in the line drains into the tank and you gotta prime it by turning the key a couple times. I'm waitin on some cash to replace the whole pump, but if it's not real old you can just do the regulator if you want
