truck wont start
Old Dec 8, 2011 | 09:51 PM
minitrucker's Avatar
minitrucker
Default truck wont start
2001 ram 1500 5.2L ive been trying to fix my truck the past few weeks with no luck! it died on the side of the road......fuel is fine and has pressure at the injectors....has injector flash....no spark....changed crank senson.....found bare wires on the cam senson changed it..... changed coil still nothing...today i changed the pcm and it fired right up....but after it idles for abit it stalled....did this like 3-4 times..... now it wont start at all again
Old Dec 9, 2011 | 09:01 AM
Are you getting spark, and injector pulse still?
Old Dec 9, 2011 | 06:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And how do you know the fuel pressure is "fine" ? Did you check with a gauge? Did you replace the cap and rotor? And did you compare the new crank sensor to the old one and what brand did you use?
Old Dec 13, 2011 | 12:38 AM
Lapseal's Avatar
Lapseal
Smile Click while starting engine
My Son has a 1996 Ram 1500 5.2 4 x 4. In excellent shape, the problem we are having is when it's cold outside and he goes to start it up, it "CLICKS" a couple of times and then turns over slightly slow then fast and fires right up. After it warms up he can shut it off and then start it right back up.
This truck has 175k and runs beautiful. I replaced the starter relay up top.
Is there a starter solenoid I can replace or should I replace the whole starter.
Thanks,
Old Dec 13, 2011 | 01:16 AM
Ramzy's Avatar
Ramzy
Sounds more to me like weak battery or corroded ground terminals. A weak battery or bad ground will do the exact same thing. If the relay or solenoid were bad it wouldn't start no matter what you do. After running it starts up just fine. This leads me to the battery issue.
