Metal Shavings in Oil. Causes?
A family member was driving my truck down the highway when the engine died (it was left in drive as it decelerated). We had it towed back home. It wouldnt start and the check gauges light and brake lights were on. I ended up replacing the alternator and battery and got it to turn over. It wouldnt start. I gave it some gas and it would run only if your foot was to the floor. I ended up checking the oil and I found metal shavings on the dipstick and the oil was metalic looking. Any idea of what could have caused this? Oil was clean before.
Rebuilding your's is an option but can get very expensive.
Metal shavings in the oil is a sure indicator of a toasted motor. Those metal shavings had to come from somewhere, and the usual source is bearing material, closely followed by iron filings from the various parts that are now grinding against each other, that shouldn't be.
Rebuild or Replacement time.
And a full out engine rebuild can cost more then a good used one or even a rebuilt one from an auto part's store, a member here recently posted prices for Advance Auto, not sure what area, think it was the 5.9 but it was around $1700.
Call some junk yards around and see what they got and what kind of warranty it has.
Yeah, getting a reman is going to end up cheaper than having the motor rebuilt. Faster turnaround too..... Labor will kill you for one guy spending several days overhauling a motor, as opposed to said motor running down an assembly line with a bunch of its brothers.
