Axel seal!!
Old Dec 12, 2011 | 06:33 PM
botta's Avatar
botta
Question Axel seal!!
im trying to get instal my front passenger axel seal. i have a slide hammer and washer but its not seating correctly, a flat head just cuts thru it. its the one by the 4x4 shift fork. any ideas on how to get this seal seated? please help!!
Old Dec 12, 2011 | 07:12 PM
99dodge318's Avatar
99dodge318
Here you go
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Dec 12, 2011 | 07:24 PM
botta's Avatar
botta
all that link tells you is u need to press it from the inside, what kind of press do i need? theres not a whole lot of room to work in the axel shaft. i custom made a slide hammer... epic fail!! like the name of tool, pic of tool, and instructions would help me out alot
Old Dec 12, 2011 | 07:46 PM
Piece of threaded rod, couple nuts, and some fat washers. (or, a socket that fits the seal nicely on that end....) assemble everything, and then use a the nut to apply pressure to the seal, to pull it into place.
Old Dec 12, 2011 | 08:00 PM
botta's Avatar
botta
so like a piece of all thread? should i not use a slide hammer?? i can weld anything together, i go to welding school.
Old Dec 12, 2011 | 08:02 PM
Pulling it steadily is far better than pounding it quickly. Less likely to trash the seal.
Old Dec 12, 2011 | 08:11 PM
botta's Avatar
botta
good idea how am i going to keep the all thread steady? should i make like a tri pod thing to pull from the spin knuckle?
Old Dec 12, 2011 | 08:17 PM
Nah. Once you get it in there, and snug it up, it will hold itself in place. You just want something on the outboard end that will let you use the nut to pull the all-thread to install the seal.
Old Dec 12, 2011 | 08:27 PM
botta's Avatar
botta
alright ill have to post a pic of what i make at school in 2 days. maybe u can tell me if it should work
Old Dec 13, 2011 | 04:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
