2000 Ram 5.2L Plugs
Old Dec 12, 2011 | 10:29 PM
Sawman85's Avatar
Sawman85
Default 2000 Ram 5.2L Plugs
I just bought a 2000 Ram and am giving it a well deserved tune up but can't get 2 of the 4 plugs to come out on the passenger side. They seem to be turning but are not coming out. I thought one plug may have stripped threads but when the second one did the same thing I figured I must be overlooking something. The other two were no issue at all. I'm new to Dodge.... got rid of an F-150 for the Ram but have done my own tune ups for 20+ years and have not run into this problem. Any suggestions?
Old Dec 13, 2011 | 08:44 AM
LoneWolfArcher's Avatar
LoneWolfArcher
Are the nuts on the plugs stripped?
Old Dec 13, 2011 | 09:00 AM
Annihilator_X9's Avatar
Annihilator_X9
Either that or the head is stripped. I soaked mine in PB Blaster for a couple days before I did them. Doing that with the temp changes from cold to hot will really work it in and they all came out easy peasy.
Hopefully somebody with a way to get those suckers out will chime in soon.
Old Dec 13, 2011 | 09:28 AM
Take the heat shields off, so you can actually get the socket down onto the plug.
Old Dec 13, 2011 | 05:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Blow the shields out with compressed air first. Then soak with penetrating oil as suggested. Also , make sure the socket is new and not cracked. And get a Haynes manual and torque the new plugs to the proper spec, and you wont have a problem removing them next time.
Old Dec 13, 2011 | 09:33 PM
Sawman85's Avatar
Sawman85
Thanks for the advise... it seems that some of the heat shields are in the way. I got one plug out tonight and soaked the rest. The heat shields are a pain to get out!
Old Dec 14, 2011 | 09:10 PM
CPTAFW163's Avatar
CPTAFW163
grab the heat shields with a pair of locking pliers, twist and pull. Then get in there with a wire brush and get out the debris. Othewise you will not get soaking to the threads.
Also, I mix PB blaster with 25% synthetic motor oil when i soak. It thins the oil and allows it to penetrate. The oil will not dry out like PB blaster does.
Take it easy, if you break a spark plug you will need to remove the head.
Old Dec 14, 2011 | 11:59 PM
sparechange's Avatar
sparechange
Might try Kroil instead of pb blaster, way better stuff
Old Dec 15, 2011 | 07:45 AM
charlie1935's Avatar
charlie1935
For penetrating oil mix acetone and ATF in a 50/50 mix.
Old Dec 15, 2011 | 06:10 PM
zman17's Avatar
zman17
Forget PB, use the Kroil, Cyclo Breakaway(my fav) or what Charles said.
