Mopar MPI
Old Dec 13, 2011 | 09:33 AM
mccart's Avatar
mccart
Default Mopar MPI
For those of you that have it, how much difference can you tell between the stock intake?
Old Dec 13, 2011 | 11:29 AM
J415's Avatar
J415
Are you talking about the air gap or the m1?
Old Dec 13, 2011 | 04:15 PM
mccart's Avatar
mccart
Ive never heard of the mopar "air gap" only the M1 and the MPI, im looking at the MPI for my 97.
Old Dec 13, 2011 | 04:26 PM
merc225hp's Avatar
merc225hp
If this is the intake you are referring to its an M1. There should be a few threads about them. If it's not post a link or pix of the one you are referring to.
Aluminum Single Plane Intake — 2-bbl MPI w/o EGR
(1998-03) 5.2L/5.9L Magnum/Jeep Engines
These MPI Intake Manifolds can be used as a direct replacement for production engines. They are designed to use production throttle body, injectors, fuel rail and other hardware from your stock intake. Available in EGR and non-EGR.
$474.95
MOP-5007852
Old Dec 13, 2011 | 04:40 PM
mccart's Avatar
mccart
Yeah, that's it. And I have another question.
Some places say the egr is from 92-96 and others say 92-97. My truck is a 97. Do you know what year they stopped the egr?
$474.95
MOP-5007852
Old Dec 13, 2011 | 06:57 PM
Hahns5.2's Avatar
Hahns5.2
95 was the last year for EGR.
You can use an EGR manifold as well and block off the port, as many others have done.
Old Dec 13, 2011 | 08:44 PM
aje1127's Avatar
aje1127
some 96's used the EGR manifold from the factory with a block off plate on them,i guess they still had many left over to use until they changed the casting in mid 96.
Old Dec 13, 2011 | 08:47 PM
gdstock's Avatar
gdstock
$500 for a replacement intake? It would have to be a gaurateed boost in performance before I would even think about a mod like that?
Old Dec 13, 2011 | 10:02 PM
FC3S Murray's Avatar
FC3S Murray
Does it boost performance?
Old Dec 13, 2011 | 10:28 PM
Hahns5.2's Avatar
Hahns5.2
Yes, but not much by itself. Like the Air Gap, on a totally stock engine you will lose some low end torque but you gain a good amount of top end, which the kegger severely lacks. When combined with some supporting parts, especially a tune, but also thing's like 1.7RRs, that low end torque will return. I've driven an identical truck to mine except a 98, bone stock, and mine has more ***** at every RPM.
