idle dropping truck turning off not starting
go figure my torque bit that fits in the screw for the tps and Iac is the only one missing from my set
looks like ill have to buy a bigger and better set
when i pulled off the hat assembly the part thats cylinder shape that sits on the throttle body it was moist dont know with what though. i flipped up the butterflys and felt inside that was damp too and REALLY REALLY dirty.
ok so i didnt bother testing the tps just went and bought one it was 35 bucks any ways i pulled it out i also pulled out the IAC the iac is FILTHY! as u said probly a blown plenum the bottom of my throttle body (i took that off as well. im going to rplace the tps and clean the throttle body as well as the IAC my next question is what should i clean the IAC with?
so i cleaned the IAC as best i could (gunna buy a new one thursday) and i installed the new tps. its better... this time when i reved it to 3000 rpms it just dropped back down to 750. it didnt go under 500 almost die than come back it just dropped to 750 or so and chilled there. now about this vent issue. nothing i do will make the vents by the radio work even if i put it only lower vents it still remains to blow from the top ones by the window. i tryed to search wild vents, "wild Vents" both with and without spaces in between words (even tryed with the quotation marks)i looked in the faq diy section and in that section even the link to old diy threads yet i cant find the thread about wild vents anybody have any links or another term i should search with?
https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Try a search for " Wacky Vents" A bunch of things come up including that link i posted for ya.
Ive read the big thread on "wacky vents" my air doesnt blow at all through the vents by the steering wheel or radio. I tryed to see if my cruise control works. (i KNOW my 4 wheel drive works) when i tryed the cruise control nothing happend at all not a light on the dash nothing its like it wasnt even there. would the vaccum leak cause the cruise control not to even light up? if so wheres the best place to look for the leak? as i said my 4 wheel drive works. also is there a way to test my pcm? my horn doesnt blow my fog lights dont run maybe my pcm is bad???
This truck is going to be the death of me or jyst make me one experienced 2nd generation tech.. Every problem that could arise has risen... My last names murphy so looks like its my law....what could go wrong will go wrong..
HeyYou's Law: Murphy was an optimist.
