how to choose timing chain and gear set?
looking on summit because am going to change my timing chain and gears over christmas break but there is a whole page of them, could somebody shed some light here.
http://www.summitracing.com/search/M...r+timing+chain
If you do a search, seems a lot of people use the mopar double roller set: mopar p5249267" ~$63 on summit. (when you go to the link you posted, select "none" in the "max. advance/retard..." category on the left side, and the mopar set will be the only one remaining.)
cloyes c3072 stock replacement for $40 is fine. its what i used.
http://www.amazon.com/Cloyes-C3072-3...ar=1&carId=003
i put the MOPAR PERFORMANCE double roller chain and gears on my 93 d150 5.2 magnum,there is a big difference.that was at 127,000,the original had almost 1inch of strech. lots of backlash making the truck stumble and almost die out. good luck
