extra money guess its 408 time
Old Dec 16, 2011 | 02:19 PM
  #51
matty675's Avatar
matty675
ARP sells different head studs for N/A applications they're only about 100 bucks
Girdle? No need for that.
Who's going to do all the work on the block? Lots of time and money there. Have you taken that into consideration?
Old Dec 16, 2011 | 02:21 PM
  #52
CPTAFW163's Avatar
CPTAFW163
I think the reason mine were expensive was because I needed smaller studs where the fastener was to get the rocker arms on my twisted wedge heads (Clearance issues). Never get heads from a ford aftermarket company for your chevy!!!
Old Dec 16, 2011 | 02:23 PM
  #53
dipsherry's Avatar
dipsherry
Originally Posted by CPTAFW163
Matty, do you really need head studs over head bolts in a non-boost application? I had APR 12 point studs on my camaro and those suckers cost about a GRAND!!! I can't believe I spent that much on fasteners.
i am thinking the same thing.... A small shot of no2 should not blow the heads of the block or even if i do go with a procharger down the road i think i would be safe at the 4lb they make
Old Dec 16, 2011 | 02:34 PM
  #54
matty675's Avatar
matty675
In any case boosting an engine, reduces reliability. The more boost, the more risk you are taking.
Get studs, not the $1k set, the MUCH cheaper set. Studs are for many reasons, the better option.
If you are procharging it, you need the ARP studs for boosted apps. They are expensive. If you are juicing it you need them as well. WHY SKIMP?
The issue is not "blowing the heads off the block", fasteners stretch. Boost will eventually render ordinary studs incapable of holding the seal between the deck and heads.
Who's doing your machine work?
Old Dec 16, 2011 | 02:53 PM
  #55
dipsherry's Avatar
dipsherry
i got a guy who owns a machine shop doing all the work i am looking at about $1000 for all the build and install as long as i help after work...i thought the girdle was just extra saftey precaution to strengthen up the bottom end
Old Dec 16, 2011 | 03:01 PM
  #56
dipsherry's Avatar
dipsherry
http://mustangspecialtiesinc.com/
thats who is doing the work.
I am going with the arp studs for boosted apps...just for saftey precautions same reason i got forged internals vs the cast i only want to do this build once
Old Dec 16, 2011 | 07:40 PM
  #57
Adobedude's Avatar
Adobedude
Girdle is worthless...Don't buy into the hype.
Old Dec 17, 2011 | 07:46 PM
  #58
dipsherry's Avatar
dipsherry
thanks for the advice
Old Dec 17, 2011 | 07:48 PM
  #59
dipsherry's Avatar
dipsherry
just picked up a aps trans with the works was $5100 i paid 1450 with 12k miles
Old Dec 17, 2011 | 08:55 PM
  #60
Adobedude's Avatar
Adobedude
I wanted one too....This guy said they're junk.
http://www.shadydellspeedshop.com/
Ryan Johnson. He's one of the best small Block Mopar guys out there...All he does is SBM.
