no oil pressure
i know this is kinda off topic but how hard is it to find a 94 1500 with red seats, carpet, dash, etc?? my dash is messed up.(i know its common in dodge) and my center fold up seat is broken (due to a break in). is red like a rare color?? the outside is factory white.
ok so i fixed my truck today, the oil pump had a crack it the top the shaft that goes in the top of the pump wasnt seated correctly. then after i fixed that problem. now my oil at a driving temp with rpm at 1.5, my pump runs at 20psi, and just above 0 at idle.
That's bad.
Did you use a stock pump? High volume? Oil level up to snuff?
I am thinkin' you are going to need to drop the pan again, and do bearings....... either that, or rebuild the motor now, while it is 'cheap', and you DON'T have to replace things like the crank, and rods.....
i used a stock pump, i hope the tube for the gauge isnt just clogged. when i first started it today it ran at about 70psi.. then is just slowly dropped. my pick up tube was all dirty and i think something got pass the pick up tube and clogged the gauge.
