no oil pressure
Old Dec 14, 2011 | 06:19 PM
botta's Avatar
botta
Question no oil pressure
so i changed the oil pump, cleaned the pick up tube, and have a manual oil pressure gauge, i have no oil pressure at all what so ever and the motor is starting to get a little knock. im not driving it just trying to get oil pressure. what do i need to do??
Old Dec 14, 2011 | 06:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you prime the pump ? And why start another thread? Just add it to the original one. This way people that want to reply, no the history of what's going on. Not to mention the fix if you get it figured out.
Old Dec 14, 2011 | 06:52 PM
botta's Avatar
botta
no i didnt prime it, and i didnt think to put it on the old thread. i am kinda still gettn use to how these things work. how do u prime the pump??
Old Dec 14, 2011 | 06:56 PM
redneck_ram's Avatar
redneck_ram
if you dont prime the pump its gong to take a while to get pressure(or not at all). i primed mine, and had pressure within 5-10 seconds of first start-up after replacing pump, and screen. just did it to mine on dec. 4th. i have a mech. gauge too, and have great oil psi. time to take it back apart and prime it and do it right.
here is the correct way to do it.
Old Dec 14, 2011 | 07:05 PM
botta's Avatar
botta
so i have to pour oil in the end that goes to the block, until it come out of the pick up tube?? thats how u prime it?
Old Dec 14, 2011 | 07:08 PM
zman17's Avatar
zman17
This is where having a Haynes manual and downloaded one of the free service manuals form the FAQ/DIY section comes into play. And didn't the pump come with directions? Not to mention, are you sure the shaft was aligned and not twisted or broke?
Old Dec 14, 2011 | 07:13 PM
It won't come out the pickup tube, you will just fill the cavity available, down to the gears. This is a necessary step though...... you 'might' be able to pull the sending unit, and use a funnel to fill the upper part with oil..... maybe. Pulling the pan again would be safest though. While you are in there, you can also have a look at your rod/main bearings, and see if you have done any damage.
Old Dec 14, 2011 | 08:43 PM
redneck_ram
when i primed mine i did it until it came out the pickup tube just to be on the safe side, seeing how it was the first time id ever done anything like it before.
Old Dec 14, 2011 | 08:46 PM
What pump did you use? Mine filled up, and I didn't see any out the pickup tube until I turned the pump.
Old Dec 14, 2011 | 09:44 PM
redneck_ram
melling oe replacement. i only had a little bit run out. maybe i turned it the other way.. i dont remember, haha.
