Sea foam
Old Dec 15, 2011 | 08:06 PM
KxRideRon125's Avatar
KxRideRon125
wat about the sea foam spray ur suppose to be able to spray it into the intake
Old Dec 15, 2011 | 08:47 PM
peshewa's Avatar
peshewa
Seafoam - I have seen multiple threads on here where people got hydro locked from using it. Other folks I know who used it in the tank only had about 4-6 weeks before the O2 sensors went out. I would say stay away from that stuff. Every other tank, I use Berymans B12 chem tool available most anywhere, it does not kill the O2 sensors. Back in the days of carbs, you could drizzle a little ATF in the carb & it would do a fine job of cleaning crap out, but newer engines have a lot tighter tolerances & sea foam is over glorified ATF. The 1 thing I have used for years with consistent measurable success is zmax. No damage to sensors, no hydro lock & it actually does all it claims to in all the vehicles I have put it in.
Old Dec 15, 2011 | 08:54 PM
Augiedoggy's Avatar
Augiedoggy
Any liquid can hydro lock the engine if added wrong... There are a lot of kids here who dont follow directions. ( hell I dont follow them) that has nothing to do with seafoam.
Seafoam is safe tested for o2 sensors I have put a couple bottles through mine already with no problems... marvels mystery oil used to work great oo but its not safe for cat converters I think... I use it in my vw though and is does the job...
Old Dec 15, 2011 | 08:55 PM
KxRideRon125
ya its was operator error i think on whoevers part that hyrdolocked it lol
Old Dec 15, 2011 | 09:43 PM
Dycrow27's Avatar
Dycrow27
I ran some through my tank, oil, and brake booster..... After reading this i am wondering if i should of did it through my oil??? I just changed it and it wasn't real runny but had a brown tint to it. What should i do to make sure it doesn't mess my motor up
Old Dec 15, 2011 | 10:08 PM
If you already changed the oil, and didn't add any more, than you have already dealt with it. If you added some after you changed the oil, change it again.
Old Dec 15, 2011 | 10:16 PM
gdstock's Avatar
gdstock
Originally Posted by KxRideRon125
so its a really bad idea to put it in the oil
let's see......unless you want this to happen -"It will break up the slidge and residue that is holding your compression normal. Then you may get blow by when it is washed away" - - - -then YES! Really bad!
Old Dec 22, 2011 | 04:52 PM
KxRideRon125
well i just ran sea foam in my truck thru my brake booster line and my idle is sooo much smoother now and a $h** load of smoke came out haha
Old Dec 22, 2011 | 05:08 PM
stewie01's Avatar
stewie01
I'm thinking about doing SeaFoam when I fix my plenum. Should I do it before or after I replace the pan and plate?
Old Dec 22, 2011 | 05:33 PM
Augiedoggy's Avatar
Augiedoggy
is your plenum gasket blown or are you just assuming?.. I did mine like 5,000 miles ago and since I barely drive it I decided to do it again a couple days ago the correct way through brake booster...I hardly got any smoke this time unlike the last time when it smoked a lot! Thats a good sign I guess...
