Sea foam
Old Dec 14, 2011 | 10:20 PM
KxRideRon125's Avatar
KxRideRon125
Default Sea foam
well its getting close to that time to change my oil and i was thinkin about putting some sea foam thru the brake booster line before i do....anybody hav any tips on the best way to go about using sea foam and does it work well
Old Dec 14, 2011 | 10:28 PM
J415's Avatar
J415
Type "seafoam" into the DF search engine and there are TONS.
Old Dec 15, 2011 | 06:25 PM
KxRideRon125
i looked up sea foam and didn't gt really the results i wanted i just want to know if anybody has used it before and wats the best way to go about using it
Old Dec 15, 2011 | 06:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A lot of people on DF use it with good results. And most of them read the can on how to do it. LOL Just don't put it in your oil.
Old Dec 15, 2011 | 06:35 PM
kejobe's Avatar
kejobe
I had my wife hold rpm's up while I let the booster vac line suck up roughly 1/3 bottle. Then dumped 1/3 in throttle body while running (doing this will kill the engine). Let it sit for 10-15 minutes. Dumped the rest in gas tank. Started it up (cranked a few times), when it fired I had to keep on the gas to keep it running. In the meantime, it smoked like a b*tch for a few minutes then cleared up and ran on its own again.
It "seemed" to run a little better after doing this.
Old Dec 15, 2011 | 06:50 PM
zman17's Avatar
zman17
Don't have anyone holding the throttle open. Just start the engine, remove the brake booster hose, and let the vacuum suck it out of the can into the hose "slowly" without letting the engine stall.
Old Dec 15, 2011 | 06:53 PM
KxRideRon125
haha ok so ill use 1/3 of the can in the booster line 1/3 in the gas ....but wat happens if u put it in the oil
Old Dec 15, 2011 | 06:58 PM
kejobe's Avatar
kejobe
Guess I should have been a little more specific. She only held it at about 1500 rpm.
Old Dec 15, 2011 | 07:08 PM
CPTAFW163's Avatar
CPTAFW163
It will break up the slidge and residue that is holding your compression normal. Then you may get blow by when it is washed away.
It is the same as if you put synthetic oil in a car that has used Dino oil for 70K and over. It loosens the sludge and transports it around your whole engine.
Old Dec 15, 2011 | 07:51 PM
KxRideRon125
so its a really bad idea to put it in the oil
