wobbles and shakes
I agree, shaking at different speeds and not at others is usually indicative of tire/ wheel imbalance. I would take it to a tire shop that can check for imbalances in the tire wheel assembly to make sure the tires and wheels are good. Have them check for runout & high/ low spots. If that is all good have them balanced and go from there worth a try anyway for probably about $35 - $50. The problem may also be alignment, but i would check the tires first. I know that my 1500 is extremely sensitive to road crown and likes to wander when in the left lane on the highway.
Yup, take it to a tire shop before you give up and sell it, a shop here in town does tire balancing for $5 a tire, just depends on where you take it.
A visit to the alignment shop would cost a little more but they should be able to tell you if you need to replace any steering/suspension components on the front end.
