wobbles and shakes
Old Dec 16, 2011 | 10:53 PM
media1988's Avatar
media1988
Default wobbles and shakes
hey all just bought a 1998 dodge ram with 2500 axles 13 inch lift and 42's. should not have done this thought i had the knowledge i dont. when driving the truck vibrates and shakes pretty bad but only a certian speeds. yes the steering has a little play everything looks tight and it has a new track bar. has a fox steering stabilizer. it doesnt shake like death wobble it almost feels like its bouncing but only side to side up and down when hitting a bump is fine. please help or at least get me in the right direction anyone near me can help media pa?
Old Dec 16, 2011 | 10:56 PM
media1988's Avatar
media1988
http://s1191.photobucket.com/albums/z471/NicholasLeeBenegar/
check out all the pics there is also a front view of the suspension.
my friend was riding behind said it looked fine but it looked like the truck was shaking
Old Dec 16, 2011 | 10:58 PM
media1988's Avatar
media1988
media1988's Avatar
media1988
Old Dec 16, 2011 | 10:59 PM
media1988's Avatar
media1988
almost kind of like a swaying with bouncing. now that i think of it does it even look like i have a sway bar?
Old Dec 17, 2011 | 12:06 AM
dlyter09's Avatar
dlyter09
That looks to be a negative on the swaybar... Any other pictures?
Old Dec 17, 2011 | 02:21 AM
media1988's Avatar
media1988
I'm assuming thats my problem....would that cause a bumpy wiggle type of ride? More importantly do i get a sway bar for a 2500 or 1500
Old Dec 17, 2011 | 03:03 AM
media1988's Avatar
media1988
Also has a new track bar installed
Old Dec 17, 2011 | 06:52 AM
THE NIGHT TRAIN's Avatar
THE NIGHT TRAIN
New Member
are your tires bias ply? I had a set of 36 inch bias ply ground hogs years ago and in cold weather they would flat spot , causing the truck to shimmy and shake horribly.
Old Dec 17, 2011 | 10:01 AM
Night Train has a good point.
Check ALL of your steering/suspension components for slop. It looks like there are spacers above the front springs as well. Not really a good idea.
Does it start doing its' tricks at around 45mph or so? What you might be feeling is an engine miss...... Check out the plenum thread stickied at the top of this forum. Pull a couple of your plugs, and see what they look like. Cap/rotor as well.
