plenum question
Old Jan 1, 2012 | 09:25 PM
  #21
Matt Nickerson's Avatar
Matt Nickerson
Originally Posted by KxRideRon125
i watched a vid on youtube on how to go about changing the plenum gasket and it said somthing about using RTV sealent in all the corners??? why would i have to do that
I'd suggest following the instructions from Hughes Engines: http://www.hughesengines.com/Upload/...orcementV8.pdf
-No gasket sealer for the plenum gasket.
-Optional: use silicone on the four corners of the intake when you're installing the new manifold gaskets. As there is a potential for the gaskets to not seal properly, the silicone will lessen that chance. <---I did this on mine.
Old Jan 1, 2012 | 09:37 PM
  #22
KxRideRon125's Avatar
KxRideRon125
how do u release all the pressure form the fuel line....o and u dont have to remove the fuel injectors do you
Old Jan 1, 2012 | 11:37 PM
  #23
Matt Nickerson
If you have a schrader valve on the rail just push the valve down with a screwdriver and let the remaining fuel out of the lines. Or you can take out the fuel pump fuse/relay, turn the engine on--it will then stall, crank it a few times to make sure the system is depressurized.
You don't have to remove the injectors or the rails. But I did, found a cracked injector that I probably wouldn't have noticed if I didn't remove it. Also replaced the injector o-rings.
Old Jan 2, 2012 | 12:15 AM
  #24
KxRideRon125
stupid question thats not related tho this at all but how do u get ..2001 Ram 1500 4X4 M/T 318ci Eastern Hi-Flow Cat , Super 44, Hughes Plenum...that inda of stff to show up wen u post somthing
Old Jan 2, 2012 | 12:27 AM
  #25
Matt Nickerson
Click on "quick links" at the top of the page (the black bar w/ user cp, photo gallery, faq, etc.), then click 'edit signature'
or... Click on "user cp" at the top left. on that page at the left it says 'edit signature'
Old Jan 2, 2012 | 12:34 AM
  #26
KxRideRon125
cool thnx
Old Jan 2, 2012 | 07:46 AM
  #27
stewie01's Avatar
stewie01
We made a special "tool" to remove the fuel line, it was a hard round piece of plastic cut on the bottom so we could get it on the fuel line, and we used a screwdriver to push it in and release the hold on the fuel line.
No gas squirted out of the fuel line itself, but there was still some in the fuel rail...
Old Jan 2, 2012 | 01:24 PM
  #28
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by gdstock
I wondered the same thing, but never saw any reference to anyone hav ing done this successfully. I decided not to be the guinnea pig. In theory, if the bolts were shortened and torqued properly and the plate held sufficient pressure on the gasket between the bolts, the original pan should be good.
I re-used the stock plate, and used shorter bolts. No leakage so far.
Old Jan 2, 2012 | 01:45 PM
  #29
zman17's Avatar
zman17
Retired Moderator - RIP
You know you can get a set of those "special tools" at any parts store for like $3 or less right? ;
Old Jan 2, 2012 | 02:09 PM
  #30
stewie01's Avatar
stewie01
Hey man, we made this in about 5 minutes for FREE, with parts on hand
